Is VZLinux compatible with Webmin/Virtualmin?
Hello to all.
I plan to reinstall my Centos 7 VPS because OpenVZ is not compatible with Alma Linux Elevate migration tool, but unfortunately today the VPS provider said Alma Linux 9 has issues with OpenVZ only Alma Linux 8 works fine. The EOL of RHEL 8 is in 4 years, searching I discovered VZLinux that have a migration tool and is compatible with OpenVZ, the VPS provider does not have VZLinux in his OS images. I am going to try OpenVZ 9, in their web page they say:
Fully free and open-source​
Forever fully free and always open source 1:1 Red Hat Enterprise Linux clone developed for and with the Linux community.​
Supported as guest OS
Supported as a guest operating system under different hypervisors (Virtuozzo, OpenVZ and KVM) with templates in hyperscaler marketplaces.​
Easy upgrades​
Ready-to-use conversion utility for simple and on-the-fly conversion from CentOS 8 to VzLinux 8 plus the possibility to convert CentOS 7 directly to VzLinux 8.​
Since VZLinux claims “1:1 RHEL clone” can I use Virtualmin and restore the domains via Virtualmin to VZLinux 8?, so later on migrate to VZLinux 9.
The key question is: Will Virtualmin run fine on VZLinux?
Thanks and regards
joejac
I wouldn’t bet on it to be supported: OS Support | Virtualmin — Open Source Web Hosting Control Panel
If you have the chance to deploy on a test system, I would do that first and see if Webmin runs reliably on VzLinux.
if you look at the install script, its won’t detect VZLinux and fail.
You could modify it to detect it, but I would stick with a Supported OS.
There seem to be a workaround for Alma 9 Issues.
https://clients.websavers.ca/whmcs/knowledgebase/381/AlmaLinux-9.4-running-as-an-OpenVZ-container-cannot-update-initscripts-due-to-network-scripts.html
Never heard of it.
If it’s actually RHEL compatible (which is harder to achieve than it used to be), then it should work, though it probably won’t be detected correctly, and you may need to fool the installer into believing it is RHEL or Alma or Rocky. The simplest method for tricking the installer is to change the contents of /etc/redhat-release to match that of the closest supported distribution (probably any of the RHEL rebuilds would work).
The code that does that detection is here: slib/slib.sh at e297fe64e6b093a43598ae7274c015d8433f686a · virtualmin/slib · GitHub
Thanks to all for your kind answers.
Since I knew it would be hard, I moved all the first VPS customers to my second VPS server.
  1. I will try in the first server, since all customers are now moved to the second server, following @Steini advice.
  2. Virtuozzo docs are sparse but clear, I like their docs, thanks @Joe for the warning, fortunately, VZLinux has this feature, that probably will make webmin/Virtualmin work:
5. Masking VzLinux as CentOS or Redhat Enterprise Linux
https://docs.virtuozzo.com/virtuozzo_linux_8_quick_start_guide/masking.html
I will be posting the results of the attempt.
Thanks to all for your help.
Regards
joejac
  1. I was following the conversion instructions here: 4.1. Converting from CentOS 7 :
  2. Steps 1 to 5 were fine. Step 6 is optional and I skip it.
  3. On step 7, in the “upgrade check” it failed with the error:
    IOError: [Errno 2] No such file or directory: ‘/boot/grub2/grub.cfg’
  4. Following is the command output: # vzupgrade check --skip-vz with the error:
==> Processing phase `configuration_phase`
====> * ipu_workflow_config
        IPU workflow config actor
==> Processing phase `FactsCollection`
====> * read_openssh_config
        Collect information about the OpenSSH configuration.
====> * root_scanner
        Scan the system root directory and produce a message containing
====> * repository_mapping
        Produces message containing repository mapping based on provided file.
====> * system_facts
        Provides data about many facts from system.
Process Process-112:
  File "/usr/lib64/python2.7/multiprocessing/process.py", line 258, in _bootstrap
    self.run()
  File "/usr/lib64/python2.7/multiprocessing/process.py", line 114, in run
    self._target(*self._args, **self._kwargs)
  File "/usr/lib/python2.7/site-packages/leapp/repository/actor_definition.py", line 72, in _do_run
    actor_instance.run(*args, **kwargs)
  File "/usr/lib/python2.7/site-packages/leapp/actors/__init__.py", line 289, in run
    self.process(*args)
  File "/usr/share/leapp-repository/repositories/system_upgrade/common/actors/systemfacts/actor.py", line 65, in process
    bios_grubcfg_details = systemfacts.get_bios_grubcfg_details()
  File "/usr/share/leapp-repository/repositories/system_upgrade/common/actors/systemfacts/libraries/systemfacts.py", line 326, in get_bios_grubcfg_details
    with open('/boot/grub2/grub.cfg') as fo:
IOError: [Errno 2] No such file or directory: '/boot/grub2/grub.cfg'
Actor system_facts unexpectedly terminated with exit code: 1 - Please check the above details
                           ERRORS
2024-09-25 09:01:22.857386 [ERROR] Actor: repository_mapping
Message: The repository mapping file is invalid: the JSON does not match required schema (wrong field type/value): The value of "mapping" field is None, but this is not allowed
Summary:
    Hint: Read documentation at the following link for more information about how to retrieve the valid file: https://access.redhat.com/articles/3664871
                       END OF ERRORS
                     UPGRADE INHIBITED
Upgrade has been inhibited due to the following problems:
    1. Inhibitor: File "/etc/default/grub" does not exist!
Consult the pre-upgrade report for details and possible remediation.
                     UPGRADE INHIBITED
Debug output written to /var/log/leapp/leapp-preupgrade.log
                           REPORT
A report has been generated at /var/log/leapp/leapp-report.json
A report has been generated at /var/log/leapp/leapp-report.txt
                       END OF REPORT
Answerfile has been generated at /var/log/leapp/answerfile
No upgrade blockers found!
  1. I consulted with the VPS provider and this was his response:
I have not tried this particular upgrade method and would also not recommend it. Upgrades are generally problematic in my experience, a clean install is always preferable when it comes to maintaining maximum long-term stability.
  1. He also recommended AlmaLinux 8, not 9 and unfortunately he does not have VZLinux images, which is supposed to be ideal when working with OpenVZ.
I appreciate your valuable opinion, on which would be the ideal solution to this migration, if the above error would be easy to fix or if it is better to reinstall, keeping in mind that the OS will be running in OpenVZ virtualization and has to be compatible with Webmin/Virtualmin.
I am not a SysAdmin sorry :see_no_evil:.
Thanks and regards
Took a look at the site. Have you tried this on a test server yet? Just cuz you read something that sounds ‘cool’ and ‘state of the art’ doesn’t mean it’s what you really need.
Thanks, @ID10T I took precautions, and I moved all customers to other VPS. So I can do tests on this server and if something goes wrong I can reinstall an OS, and no customer will be affected. Then, with the new OS, I will move some personal websites to test for a couple of weeks and then move the customers who have the simplest websites. My goal is to install a long-term support OS in this case a good clone of RHEL 9.
Any suggestions are welcomed.
Thanks and regards.
PS. I also have 2 sets of Virtualmin backups of all customers in 2 different locations.
It sounds like you’re asking us for advice on vzupgrade errors. We can’t possibly help with that. It’s not our software, and I’ve never used it.
Thanks @Joe I understand, I posted the error in case someone has an idea of the possible solution. In the end, I will try to install AlmaLinux 9 to see if it works fine or not, I do not want to install version 8.
Regards.
