the roundcube doasn’t send mail even they shows me succesfully and when i checked the server i found that this SSL not working is there anyone can help me ?
The errors seem clear to me.
You are trying to request a certificate for names that don’t exist. Don’t do that.
If you haven’t created A records for the automatically generated aliases, you should exclude them from your certificate. You cannot get certificates for names that don’t exist.
Also, if Virtualmin is not managing DNS for your domains, you should disable the DNS feature.
can you please just guide me like what can i do exactly ?
or what for example should i write o youtube to fix it?
Thank you
Just don’t request a certificate for names you do not have in DNS. You do not have an A record for autoconfig.youriptvpro.shop
, so stop trying to request a certificate for that name.
In the Let’s Encrypt form, you can choose which names to request certs for. Click “Domain names listed here” instead of “Domains associated with this server”. (But, also disable features, in Features and Plugins, you aren’t using! You can’t be using autoconfig, because you don’t have an A record for it…it wouldn’t work without one, so just disable that feature and Virtualmin will not try to request a cert for it. You also clearly are not managing DNS with Virtualmin, because if you were you would have A records for every alias that Virtualmin automatically created, so you should disable that, too. Virtualmin thinks a lot of things are true that are not, because you haven’t told it what it’s supposed to be doing. Be honest with Virtualmin and it will be more helpful to you.)
