Hello I am have a website with domain master-schema.com and IP address https://38.242.154.32/ but when I login using ip address no ssl certificate is activated this is the first thing and second icon are not showing I think he cannot read fontawasom links and the most important it is showing the site not blocked or redirected to main domain how I solve this issue any help please
here list of issues
SSL certificate is not activated in IP address
IP address is not redirecting to domain name
I am not sure if it is save like this or not
icons are not showing in my website I don’t know why but fontawasom is the issue from network tab in inspect issue it is showing error type has been blocked by CORS
Please try to help ! access my ip and check I am getting error when I try to post a picture
When you use the IP address of your Virtualmin server, you will see a website without a SSL certificate. This is quite normal for most Virtualmin installs because Let’s Encrypt does not offer this feature - it offers SSL certificates for domain names only. If you really must have your IP address show a secure lock icon then you will have to buy and apply a SSL certificate from a CA that supports this feature. I am guessing this last.bit, I have never needed to have SSL for an IP address.
With regard to the issue of icons not showing and scripts not loading, you are experiencing a SSL mixed content error. Please Google the term for more information.
It is easy to redirect the IP address to a domain name. There are multiple methods to accomplish this. In Virtualmin, there is a default website (i.e. domain name / virtual server) which can be set via Virtualmin → Web configuration → Website Options and then set the default IP address for website to Yes.
Letsencrypt does not support SSL certificates on IP addresses
The website is unable to get following asset because it is effectively not on the same domain and that is why the font is not rendered. Your server is probably preventing this. Probably CORS
I tried that and it did not work before in my aapanel and also in this panel and I am using nginx btw and I tried through nginx but did not work files are complicated
I don’t think you should do it, although it is possible, for example with ZeroSSL. But really, why would you want to? It’s better to just use a domain name with Let’s Encrypt.
Even if you use it with an IP address and see an SSL certificate warning, your connection is still secure.
The default behavior in Apache is that when you create a VirtualHost (name-based, of course), it will always serve the “best” name-based host, if you hit something that resolves to your IP, even if it doesn’t exactly match a VirtualHost. I guess you’ve changed something to break that, if you get a website served without it redirecting. I’m not sure how that would happen, actually. I guess a VirtualHost for the IP without a name? I’ve never had it happen accidentally, so I don’t know for sure what would cause it.
What do your VirtualHosts look like? (I’m just guessing, it may be something else in the Apache configuration.)
Actually, I just tested, and current Apache behavior seems to be to simply serve an error (and you’d get a cert error, which is fine, because you’re never going to point someone at your IP, because you have names for all of your sites…no one should ever go to an IP).
# Uncomment the line below if not previously added in the file
# RewriteEngine On
# Rule to redirect to the named host
# Replace [xx.xx.xx.xx] woth your host's IP address
# Replace [yourdomain.com] with your host's proper URL
RewriteCond %{HTTP_HOST} ^xx\.xx\.xx\.xx$
RewriteRule (.*) http://yourdomain.com/$1 [R=301,L]
Therefore perhaps explain to the OP how that is achieved with nginx, I have one test install withe a lemo stack, which I don’t use so therefore don’t have the knowledge to advise the OP on how to add this to an nginx server
