I’m seeing an issue that I can’t seem to find a solution for in the virtualmin forums. When I go to generate a webalizer report, after it is done I click on “View completed report” I get an error: “Invalid PATH_INFO”… however if I go in through webalizer report then click on “view report” it works just fine. so only the button that appears after generating a report gives that error
found this in miniserv.error: Use of uninitialized value in concatenation (.) or string at /usr/libexec/webmin/webalizer/save_log.cgi line 56.
fixed a pam Authen module dependency and also updated entire system.
still seeing the error… wondering if this might be a bug in virtualmin?
PS : like odoo-jay I also made a site restoration,
So, this might be something with the “stats” folder which is filled with older files that shouldn’t be there from the new install point of view ?..
