Installing VirtualMin GPL on top of Parallels Power Panel
I didn’t realize the VPS already had Parallels Power Panel installed, and installed VirtualMin GPL on top of it.
Will this cause any conflicts or create a security hole?
JP
Well, it’s not normally something we’d recommend… each control panel has their own way of doing things, and they may conflict with each other.
It shouldn’t be a security concern (though I’d turn off the other panel).
You could always try it and see if it works. If you run into problems, that could be related to having both panels. If it does work, that’s super, and means you don’t have to reinstall everything :slight_smile:
