I just purchased a server with CentOs 6.7 32 bit installed on it
I am planning to install virtualmin on it.
Do I need to install PHP and Apache before virtualmin installation ?
Earlier I installed virtualmin and get it working successfully however it had PHP 5.3. I tried to update it to 5.5 by following a tutorial but failed and messed up whole thing.
I need PHP 5.5 for my project.
So can someone guide me how to do this and what is the best way for this?
thanks for the reply. I found that tutorial but it says
“Note that the repository providing these packages currently only provides 64 bit packages. If you are using 32 bit CentOS, there are unfortunately no PHP packages for that.”
