Installer Versions
Silly question:
I see these 2 sources for the virtualmin-install.sh script are very different versions:
v7.3.4
https://raw.githubusercontent.com/virtualmin/virtualmin-install/master/virtualmin-install.sh
v7.5.2
https://software.virtualmin.com/gpl/scripts/virtualmin-install.sh
Should we ever bother with the github version?
You absolutely should not use anything out of github unless you’re a developer working on Virtualmin or Webmin, or you’ve explicitly been told to use a github version by a developer.
