I have a fresh CentOS box at Liquid Web, and the installer fails. I’m not getting good responses from their support folks on this. (I’m not really sure the tech who responded knows Virtualmin.)
The best they can offer is that maybe there are repositories that need to be enabled for Virtualmin installation to work. I’m pretty sure that is incorrect.
Any suggestions at all?
I can’t see any errors in the log, only this at the end:
FATAL - 2017-06-05 20:53:16 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2017-06-05 20:53:16 - Cannot continue installation.
FATAL - 2017-06-05 20:53:16 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2017-06-05 20:53:16 - re-attempted after any problems have been resolved.
FATAL - 2017-06-05 20:53:16 - Removing temporary directory and files.
FATAL - 2017-06-05 20:53:16 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2017-06-05 20:53:16 - in /root/virtualmin-install.log
INFO - 2017-06-05 20:52:52 - Started installation log in /root/virtualmin-install.log
DEBUG - 2017-06-05 20:52:52 - Install mode: full
DEBUG - 2017-06-05 20:52:52 - Product: Virtualmin GPL
DEBUG - 2017-06-05 20:52:52 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2017-06-05 20:52:52 - install.sh version: 1.1.5
INFO - 2017-06-05 20:52:52 - Checking for fully qualified hostname…
INFO - 2017-06-05 20:52:52 - Hostname host is not fully qualified.
INFO - 2017-06-05 20:53:07 - Hostname OK: fully qualified as [DOMAIN]
INFO - 2017-06-05 20:53:07 - Primary address detected as [IP ADDRESS]
INFO - 2017-06-05 20:53:07 - Entry for IP [IP ADDRESS] exists in /etc/hosts.
INFO - 2017-06-05 20:53:07 - Updating with new hostname.
INFO - 2017-06-05 20:53:07 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2017-06-05 20:53:07 - Loading OS selection library…
INFO - 2017-06-05 20:53:07 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2017-06-05 20:53:07 - Loading OS list…
INFO - 2017-06-05 20:53:07 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2017-06-05 20:53:07 - Operating system name: CentOS Linux
INFO - 2017-06-05 20:53:07 - Operating system version: 6
INFO - 2017-06-05 20:53:07 - Configuring package manager for CentOS Linux 6…
INFO - 2017-06-05 20:53:07 - Disabling SELinux during installation…
INFO - 2017-06-05 20:53:07 - setenforce 0 failed: 1
INFO - 2017-06-05 20:53:07 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2017-06-05 20:53:08 - Succeeded.
INFO - 2017-06-05 20:53:08 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Setting up Install Process
Package 32:bind-utils-9.8.2-0.62.rc1.el6.x86_64 already installed and latest version
Package 2:postfix-2.6.6-8.el6.x86_64 already installed and latest version
Package perl-DBD-MySQL-4.013-3.el6.x86_64 already installed and latest version
Package 1:quota-3.17-23.el6.x86_64 already installed and latest version
Package iptables-1.4.7-16.el6.x86_64 already installed and latest version
Package openssl-1.0.1e-57.el6.x86_64 already installed and latest version
Package python-2.6.6-66.el6_8.x86_64 already installed and latest version
Package subversion-1.6.11-15.el6_7.x86_64 already installed and latest version
Package mysql-5.1.73-8.el6_8.x86_64 already installed and latest version
Package mysql-server-5.1.73-8.el6_8.x86_64 already installed and latest version
No package mariadb available.
No package mariadb-server available.
No package rh-postgresql available.
No package rh-postgresql-server available.
Package logrotate-3.7.8-28.el6.x86_64 already installed and latest version
Package webalizer-2.21_02-3.3.el6.x86_64 already installed and latest version
Package php-5.3.3-49.el6.x86_64 already installed and latest version
Package php-xml-5.3.3-49.el6.x86_64 already installed and latest version
Package php-gd-5.3.3-49.el6.x86_64 already installed and latest version
Package 1:php-pear-1.9.4-5.el6.noarch already installed and latest version
Package mod_perl-2.0.4-11.el6_5.x86_64 already installed and latest version
No package mod_python available.
Package cyrus-sasl-2.1.23-15.el6_6.2.x86_64 already installed and latest version
Package mlocate-0.22.2-6.el6.x86_64 already installed and latest version
No package perl-LWP-Protocol-https available.
Resolving Dependencies
–> Running transaction check
—> Package bind.x86_64 32:9.8.2-0.62.rc1.el6 will be installed
—> Package cyrus-sasl-gssapi.x86_64 0:2.1.23-15.el6_6.2 will be installed
—> Package dovecot.x86_64 1:2.0.9-22.el6 will be installed
—> Package httpd.x86_64 0:2.2.15-59.el6.centos will be updated
–> Processing Dependency: httpd = 2.2.15-59.el6.centos for package: httpd-manual-2.2.15-59.el6.centos.noarch
—> Package httpd.x86_64 1:2.2.15-54.el6.vm will be an update
–> Processing Dependency: httpd-tools = 1:2.2.15-54.el6.vm for package: 1:httpd-2.2.15-54.el6.vm.x86_64
—> Package mailman.x86_64 3:2.1.12-26.el6 will be installed
—> Package mod_dav_svn.x86_64 0:1.6.11-15.el6_7 will be installed
—> Package mod_ssl.x86_64 1:2.2.15-59.el6.centos will be updated
—> Package mod_ssl.x86_64 2:2.2.15-54.el6.vm will be an update
—> Package mysql-devel.x86_64 0:5.1.73-8.el6_8 will be installed
—> Package perl-Crypt-SSLeay.x86_64 0:0.57-17.el6 will be installed
—> Package perl-DBD-Pg.x86_64 0:2.15.1-4.el6_3 will be installed
–> Processing Dependency: libpq.so.5()(64bit) for package: perl-DBD-Pg-2.15.1-4.el6_3.x86_64
—> Package perl-XML-Simple.noarch 0:2.18-6.el6 will be installed
—> Package php-imap.x86_64 0:5.3.3-49.el6 will be installed
–> Processing Dependency: libc-client.so.2007()(64bit) for package: php-imap-5.3.3-49.el6.x86_64
—> Package php-mbstring.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-mysql.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-odbc.x86_64 0:5.3.3-49.el6 will be installed
–> Processing Dependency: libodbc.so.2()(64bit) for package: php-odbc-5.3.3-49.el6.x86_64
—> Package php-pgsql.x86_64 0:5.3.3-49.el6 will be installed
—> Package php-snmp.x86_64 0:5.3.3-49.el6 will be installed
–> Processing Dependency: net-snmp for package: php-snmp-5.3.3-49.el6.x86_64
—> Package php-xmlrpc.x86_64 0:5.3.3-49.el6 will be installed
—> Package postgresql.x86_64 0:8.4.20-7.el6 will be installed
—> Package postgresql-server.x86_64 0:8.4.20-7.el6 will be installed
—> Package procmail.x86_64 0:3.22-25.1.el6_5.1 will be installed
—> Package ruby.x86_64 0:1.8.7.374-5.el6 will be installed
–> Processing Dependency: ruby-libs = 1.8.7.374-5.el6 for package: ruby-1.8.7.374-5.el6.x86_64
–> Processing Dependency: libruby.so.1.8()(64bit) for package: ruby-1.8.7.374-5.el6.x86_64
—> Package ruby-devel.x86_64 0:1.8.7.374-5.el6 will be installed
—> Package rubygems.noarch 0:1.3.7-5.el6 will be installed
–> Processing Dependency: ruby-rdoc for package: rubygems-1.3.7-5.el6.noarch
—> Package spamassassin.x86_64 0:3.3.1-3.el6 will be installed
–> Processing Dependency: perl(NetAddr::IP) >= 4.000 for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(IO::Zlib) >= 1.04 for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Archive::Tar) >= 1.23 for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Time::HiRes) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Net::DNS) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Mail::DKIM) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(IO::Socket::SSL) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(IO::Socket::INET6) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Encode::Detect) for package: spamassassin-3.3.1-3.el6.x86_64
–> Processing Dependency: perl(Archive::Tar) for package: spamassassin-3.3.1-3.el6.x86_64
—> Package httpd-tools.x86_64 0:2.2.15-59.el6.centos will be updated
—> Package httpd-tools.x86_64 1:2.2.15-54.el6.vm will be an update
—> Package libc-client.x86_64 0:2007e-11.el6 will be installed
—> Package net-snmp.x86_64 1:5.5-60.el6 will be installed
—> Package perl-Archive-Tar.x86_64 0:1.58-144.el6 will be installed
–> Processing Dependency: perl(Package::Constants) for package: perl-Archive-Tar-1.58-144.el6.x86_64
—> Package perl-Encode-Detect.x86_64 0:1.01-2.el6 will be installed
—> Package perl-IO-Socket-INET6.noarch 0:2.56-4.el6 will be installed
–> Processing Dependency: perl(Socket6) for package: perl-IO-Socket-INET6-2.56-4.el6.noarch
—> Package perl-IO-Socket-SSL.noarch 0:1.31-3.el6_8.2 will be installed
–> Processing Dependency: perl-Net-SSLeay >= 1.35-10.el6_8.1 for package: perl-IO-Socket-SSL-1.31-3.el6_8.2.noarch
–> Processing Dependency: perl(Net::LibIDN) for package: perl-IO-Socket-SSL-1.31-3.el6_8.2.noarch
—> Package perl-IO-Zlib.x86_64 1:1.09-144.el6 will be installed
—> Package perl-Mail-DKIM.noarch 0:0.37-2.el6 will be installed
–> Processing Dependency: perl(Mail::Address) for package: perl-Mail-DKIM-0.37-2.el6.noarch
–> Processing Dependency: perl(Digest::SHA) for package: perl-Mail-DKIM-0.37-2.el6.noarch
–> Processing Dependency: perl(Crypt::OpenSSL::RSA) for package: perl-Mail-DKIM-0.37-2.el6.noarch
—> Package perl-Net-DNS.x86_64 0:0.65-5.el6 will be installed
–> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS-0.65-5.el6.x86_64
—> Package perl-NetAddr-IP.x86_64 0:4.027-7.el6 will be installed
—> Package perl-Time-HiRes.x86_64 4:1.9721-144.el6 will be installed
—> Package postgresql-libs.x86_64 0:8.4.20-7.el6 will be installed
—> Package ruby-libs.x86_64 0:1.8.7.374-5.el6 will be installed
–> Processing Dependency: libreadline.so.5()(64bit) for package: ruby-libs-1.8.7.374-5.el6.x86_64
—> Package ruby-rdoc.x86_64 0:1.8.7.374-5.el6 will be installed
–> Processing Dependency: ruby-irb = 1.8.7.374-5.el6 for package: ruby-rdoc-1.8.7.374-5.el6.x86_64
—> Package unixODBC.x86_64 0:2.2.14-14.el6 will be installed
–> Processing Dependency: libltdl.so.7()(64bit) for package: unixODBC-2.2.14-14.el6.x86_64
—> Package compat-readline5.x86_64 0:5.2-17.1.el6 will be installed
—> Package libtool-ltdl.x86_64 0:2.2.6-15.5.el6 will be installed
—> Package perl-Crypt-OpenSSL-RSA.x86_64 0:0.25-10.1.el6 will be installed
–> Processing Dependency: perl(Crypt::OpenSSL::Random) for package: perl-Crypt-OpenSSL-RSA-0.25-10.1.el6.x86_64
–> Processing Dependency: perl(Crypt::OpenSSL::Bignum) for package: perl-Crypt-OpenSSL-RSA-0.25-10.1.el6.x86_64
—> Package perl-Digest-HMAC.noarch 0:1.01-22.el6 will be installed
—> Package perl-Digest-SHA.x86_64 1:5.47-144.el6 will be installed
—> Package perl-MailTools.noarch 0:2.04-4.el6 will be installed
–> Processing Dependency: perl(Date::Parse) for package: perl-MailTools-2.04-4.el6.noarch
–> Processing Dependency: perl(Date::Format) for package: perl-MailTools-2.04-4.el6.noarch
—> Package perl-Net-LibIDN.x86_64 0:0.12-3.el6 will be installed
—> Package perl-Net-SSLeay.x86_64 0:1.35-10.el6_8.1 will be installed
—> Package perl-Package-Constants.x86_64 1:0.02-144.el6 will be installed
—> Package perl-Socket6.x86_64 0:0.23-4.el6 will be installed
—> Package ruby-irb.x86_64 0:1.8.7.374-5.el6 will be installed
—> Package perl-Crypt-OpenSSL-Bignum.x86_64 0:0.04-8.1.el6 will be installed
—> Package perl-Crypt-OpenSSL-Random.x86_64 0:0.04-9.1.el6 will be installed
—> Package perl-TimeDate.noarch 1:1.16-13.el6 will be installed
–> Finished Dependency Resolution
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
