Installation Issuse,
Debian-40-etch-64-LAMP:/tmp# /bin/sh install.sh
Welcome to the Virtualmin GPL installer, version EA4.2
WARNING: This is an Early Adopter release.
The installation is quite stable and functional when run on a freshly
installed supported Operating System, but upgrades from existing .wbm-
based systems, or systems that already have Apache VirtualHost
directives or mail users, will very likely run into numerous problems.
Please read the Virtualmin and Early Adopter FAQs before proceeding if
your system is not a freshly installed and supported OS.
This script is not intended to update your system. It should only be
used to install Virtualmin Professional, or to upgrade a Virtualmin
GPL system that was installed manually via .wbm packages. If you have
previously installed Virtualmin via this script or the GPL version of
this script, upgrades and updates should be handled within Virtualmin
only.
The systems currently supported by our install.sh are:
CentOS 5 on i386 and x86_64
Debian 4.0 on i386 and amd64
If your OS is not listed above, this script will fail and attempting
to run it on an unsupported OS is not recommended, or supported. The
recommended operating systems for Virtualmin Professional, and more
details about them, can be found here:
http://www.virtualmin.com/os-support.html
Continue? (y/n) Y
Checking for curl or wget…found /usr/bin/wget -nv
Checking for perl…found /usr/bin/perl
01:55:00 URL:http://software.virtualmin.com/lib/spinner [182/182] -> “spinner” [1]
Loading log4sh logging library…
01:55:01 URL:http://software.virtualmin.com/lib/log4sh [21395/21395] -> “log4sh” [1]
INFO - Started installation log in virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as kocubaba.com
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
01:55:02 URL:http://software.virtualmin.com/lib/oschooser.pl [4448/4448] -> “oschooser.pl” [1]
INFO - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - Loading OS list…
01:55:02 URL:http://software.virtualmin.com/lib/os_list.txt [3473/3473] -> “os_list.txt” [1]
INFO - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - Operating system name: Debian Linux
INFO - Operating system version: 4.0
INFO - Installing virtualmin-release package for Debian Linux 4.0…
INFO - Enabling universe repositories, if not already available…
Get:1 http://security.debian.org etch/updates Release.gpg [189B]
Hit http://security.debian.org etch/updates Release
Get:2 http://ftp.freenet.de etch Release.gpg [378B]
Ign http://security.debian.org etch/updates/main Packages/DiffIndex
Ign http://security.debian.org etch/updates/contrib Packages/DiffIndex
Hit http://ftp.freenet.de etch Release
Ign http://security.debian.org etch/updates/non-free Packages/DiffIndex
Ign http://security.debian.org etch/updates/main Sources/DiffIndex
Ign http://security.debian.org etch/updates/contrib Sources/DiffIndex
Ign http://security.debian.org etch/updates/non-free Sources/DiffIndex
Hit http://security.debian.org etch/updates/main Packages
Hit http://security.debian.org etch/updates/contrib Packages
Hit http://security.debian.org etch/updates/non-free Packages
Hit http://security.debian.org etch/updates/main Sources
Hit http://security.debian.org etch/updates/contrib Sources
Hit http://security.debian.org etch/updates/non-free Sources
Ign http://ftp.freenet.de etch/main Packages/DiffIndex
Ign http://ftp.freenet.de etch/non-free Packages/DiffIndex
Ign http://ftp.freenet.de etch/contrib Packages/DiffIndex
Ign http://ftp.freenet.de etch/main Sources/DiffIndex
Ign http://ftp.freenet.de etch/non-free Sources/DiffIndex
Ign http://ftp.freenet.de etch/contrib Sources/DiffIndex
Hit http://ftp.freenet.de etch/main Packages
Hit http://ftp.freenet.de etch/non-free Packages
Hit http://ftp.freenet.de etch/contrib Packages
Hit http://ftp.freenet.de etch/main Sources
Hit http://ftp.freenet.de etch/non-free Sources
Hit http://ftp.freenet.de etch/contrib Sources
Fetched 2B in 0s (11B/s)
Reading package lists… Done
INFO - Cleaning up apt headers and packages, so we can start fresh…
INFO -
01:55:04 URL:http://software.virtualmin.com/lib/apt.conf.noninteractive [243/243] -> “apt.conf.noninteractive” [1]
INFO - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - Disabling any CD-based apt repositories so the process can run without assistance
INFO - Installing Webmin and Virtualmin package signing keys…
01:55:05 URL:http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin [1690/1690] -> “RPM-GPG-KEY-virtualmin” [1]
INFO - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
01:55:05 URL:http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin [1320/1320] -> “RPM-GPG-KEY-webmin” [1]
INFO - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - OK
INFO - OK
INFO - Get:1
INFO - Removing Debian standard Webmin package, if they exist (because they’re broken)…
INFO - Removing Debian apache packages…
INFO - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-tls postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl
INFO - …in progress, please wait… -dpkg: error processing /var/cache/apt/archives/usermin_1.320_all.deb (–unpack):
subprocess pre-installation script returned error exit status 2
dpkg: error processing /var/cache/apt/archives/webmin_1.380_all.deb (–unpack):
E: Sub-process /usr/bin/dpkg returned an error code (1) …in progress, please wait… failed. Error (if any): 0
Displaying the last 15 lines of the install.log to help troubleshoot this problem:
libxml-simple-perl is already the newest version.
libcrypt-ssleay-perl is already the newest version.
The following NEW packages will be installed:
usermin webmin
0 upgraded, 2 newly installed, 0 to remove and 45 not upgraded.
Need to get 18.4MB of archives.
After unpacking 108MB of additional disk space will be used.
Get:1 http://software.virtualmin.com virtualmin-etch/main usermin 1.320 [5386kB]
Get:2 http://software.virtualmin.com virtualmin-etch/main webmin 1.380 [13.0MB]
Fetched 18.4MB in 31s (591kB/s)
(Reading database … 25978 files and directories currently installed.)
Unpacking usermin (from …/archives/usermin_1.320_all.deb) …
Port 20000 is already in use
Unpacking webmin (from …/archives/webmin_1.380_all.deb) …
Port 10000 is already in use
FATAL - Fatal Error Occurred: Something went wrong during installation: 1
FATAL - in /root/virtualmin-install.log.
???<br><br>Post edited by: TrippleEx, at: 2008/01/23 15:00
You’ve already got Webmin and Usermin installed from some other source (i.e., not the Webmin.com deb packages), perhaps? If so, get rid of them, or at least shut them down.
Yes the Webmin and Usermin allready installed on the Server, but i want only add Virtualmin to webmin, how can i do it?
(Sorry for my Bad English)
Best Regards
The install.sh script assumes a fresh OS install. If you have an existing system, you’ll have to perform a manual installation of all of the various modules and configure things. If it’s a fresh OS install, plus Webmin and Usermin (i.e., you haven’t actually setup any virtual servers or anything in Apache or Postfix), you should just stop Webmin and Usermin and run the install script again.
Manual installation isn’t really covered very well by the documentation at the moment…I’m hoping to add some more details soon.
Hey Joe thanks for your fast reaply,
i do install to my Server a blank minimal Debian 4 Image (32 Bit), and than i install the Virtualmin install Script an get this Message:
INFO - Installing Virtualmin and all related packages now using the command: INFO - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base INFO - ...in progress, please wait... |Failed to fetch http://debian.hetzner.de/packages/pool/main/libn/libnet-daemon-perl/libnet-daemon-perl_0.38-1.1_all.deb Error reading from server - read (104 Connection reset by peer) Failed to fetch http://debian.hetzner.de/packages/pool/main/libg/libgd2/libgd2-xpm_2.0.33-5.2_i386.deb Error reading from server - read (104 Connection reset by peer) Failed to fetch http://debian.hetzner.de/packages/pool/main/libh/libhtml-tree-perl/libhtml-tree-perl_3.19.01-2_all.deb Error reading from server - read (104 Connection reset by peer) Failed to fetch http://debian.hetzner.de/security/pool/updates/main/p/postgresql-7.4/postgresql-client-7.4_7.4.19-0etch1_i386.deb Error reading from server - read (104 Connection reset by peer) E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? ...in progress, please wait... failed. Error (if any): 0
Get:121 http://debian.hetzner.de etch/main proftpd-doc 1.3.0-19 [493kB]
Get:122 http://debian.hetzner.de etch/main quota 3.14-7 [466kB]
Get:123 http://debian.hetzner.de etch/main rdoc1.8 1.8.5-4etch1 [310kB]
Get:124 http://debian.hetzner.de etch/main rdoc 1.8.2-1 [3856B]
Get:125 http://debian.hetzner.de etch/main ri1.8 1.8.5-4etch1 [1245kB]
Get:126 http://debian.hetzner.de etch/main ri 1.8.2-1 [3766B]
Get:127 http://debian.hetzner.de etch/main sasl2-bin 2.1.22.dfsg1-8 [124kB]
Get:128 http://debian.hetzner.de etch/updates/main scponly 4.6-1etch1 [33.4kB]
Get:129 http://debian.hetzner.de etch/main spamassassin 3.1.7-2 [974kB]
Get:130 http://debian.hetzner.de etch/main spamc 3.1.7-2 [75.2kB]
Get:131 http://debian.hetzner.de etch/main subversion 1.4.2dfsg1-2 [1027kB]
Get:132 http://debian.hetzner.de etch/main pflogsumm 1.1.0-3 [51.3kB]
Get:133 http://debian.hetzner.de etch/updates/main libcurl3 7.15.5-1etch1 [168kB]
Get:134 http://debian.hetzner.de etch/updates/main libapache-mod-php4 6:4.4.4-8+etch4 [1596kB]
Fetched 110MB in 23s (4665kB/s)
FATAL - Fatal Error Occurred: Installation failed: 1
Debian-40-etch-32-minimal:/tmp#
Whts the Problem now ?
