Hoping someone here can shed some light on an issue I’ve been having trying to install Virtualmin on a new VPS (DigitalOcean 512MB/Ubuntu 14.04, though it happens identically on 16.04 and a 1GB VPS). I’ve had a scout through the forums, and I can’t see anyone else having the same issue.
Using install.sh (freshly wget’d each time), it always fails at some point during the installation of virtualmin-base, throwing errors as below.
I’m at my wit’s end, as I’m getting the same failures regardless of Ubuntu version or VPS size. I’ve tried reimaging the VPS, and deleting it and creating a brand new one, all with the same result! I’ve had Virtualmin working previously on a 14.04 512MB DigitalOcean VPS, so I’m a bit confused about what’s changed. Any ideas?
Thanks in advance,
Freddie
Full logs here, if its any help!
INFO - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install bsdutils postfix postfix-pcre webmin usermin ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail procmail-wrapper libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libapache2-mod-php5 php5-mysql ntpdate: Succeeded.
INFO - Succeeded.
INFO - Installing Virtualmin and all related packages now using the command:
INFO - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base
...in progress, please wait...
................................Use of uninitialized value in numeric eq (==) at /usr/share/webmin/bind8/bind8-lib.pl line 537.
Use of uninitialized value in numeric eq (==) at /usr/share/webmin/bind8/bind8-lib.pl line 543.
..Enabling quotas on filesystem for /home
...........dpkg: error processing package virtualmin-base (--configure):
subprocess installed post-installation script was killed by signal (Killed)
virtualmin-base
E: Sub-process /usr/bin/dpkg returned an error code (1)
/usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
Enabling status monitoring
Hiding the Webmin upgrade page
convertquota: You have to specify action to perform.
convertquota: Utility for converting quota files.
Usage:
convertquota [options] mountpoint
-u, --user convert user quota file
-g, --group convert group quota file
-e, --convert-endian convert quota file to correct endianity
-f, --convert-format oldfmt,newfmt convert from old to VFSv0 quota format
-h, --help show this help text and exit
-V, --version output version information and exit
convertquota: Bugs to jack@suse.cz
WARN - apt-get seems to have failed. Are you sure your OS and version is supported?
WARN - http://www.virtualmin.com/os-support
FATAL - Fatal Error Occurred: Installation failed: 0
