I am re-installing VM on my debian 4.0 server after having issues with the first installation. This is a purchased license.
The first installation worked fine for a while (a couple days) then I kept getting “Error - File Not Found” errors when I tried to select options in the left hand frame of the control screen. Try as a I might, I couldnt resolve the issue and didn’t find anything in the Forums about it either. So, in order to get smarter, I decided to reinstall based upon reinstallation instructions I found in the forum.
NOW, during the installation I get all kinds of errors when the script tries to download software from software.virtualmin.com. The errors are:
Failed to fetch http://zzzzzz:xxxxxx@software.virtualmin.com/debian/dists/virtualmin-etch/main/binary-i386/Packages.gz Sub-process gzip returned an error code (1)
Err http://software.virtualmin.com virtualmin-etch/main Packages
Is the server down? Did I do the reinstallation incorrectly?
All assistance is appreciated!
Thorndike
Post edited by: thorndike, at: 2008/04/01 07:13<br><br>Post edited by: thorndike, at: 2008/04/01 07:31
