Newly installed centos 6.2 and can not install Virtualmin. Try now with CentOS 6.3 and Virtualmin install nor can I see the log and in both cases is the same error:
rh-postgresql package not available
No package rh-postgresql-server available
And I do not find these packages in any repository
In fact it seems that these packages do not exist
The package not found notices aren’t fatal errors… can you grab your /root/virtualmin-install.log file, and attach that to this post? That may offer some additional insight into what’s going on.
Are you using a VPS there? Or is that a dedicated server?
If it’s a VPS, what type of VPS is it?
I see two errors in your log that are likely related – one is a problem disabling SELinux. and the other is an issue installing the “virtualmin-release-latest.noarch.rpm” package.
What output do you receive if you run these two commands as root:
Preparing… ############## 100%
1:virtualmin-release ############## 100%
Running updatedb so locate works…this will take a little while.
/var/tmp/rpm.y6w5mq: line 12: updatedb:command not found
Attempting to import various system RPM-GPG-KEY files…Errors may occur,
if you´ve already import them. It is safe ti ignore these errors.
/var/tmp/rpm-tmp.y6w5mq: line39: locate command not found
Well, as I mentioned above – those are warnings, not fatal errors… those won’t cause the installation to fail.
Those two packages aren’t available on newer CentOS installs, only older ones – but that doesn’t prevent Virtualmin from installing, it just generates those warnings while doing so.
So the issue you’re seeing isn’t related to that, it’s something else
Can you post the current virtualmin-install.log from your latest install attempt?
Preparing… ############## 100% 1:virtualmin-release ############## 100% Running updatedb so locate works…this will take a little while. Attempting to import various system RPM-GPG-KEY files…Errors may occur, if you´ve already import them. It is safe to ignore these errors.
