Hi. I just did a new installation of Virtualmin on a new instance of Ubuntu 16.04 on Amazon using the shell script. Everything went well, but after installation I realized that the shell installed a whole bunch of stuff I really don’t want to support, for example BIND, ruby, postgres and mail servers. I removed them via apt, and I think that’s where some problems started.
During one of those removals, apparently apache got included. I reinstalled it. However in working through the Virtualmin config check I needed to reinstall mod_suexec, so I installed mod_suexec_custom. At this point the config check states that my “system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home.”. How do I fix this?
Also, when I run some scripts I am frequently getting “sudo: unable to resolve host ip-xxx-xx-x-xxx” where “ip-xxx-xx-x-xxx” is the literal hostname assigned by Amazon using the private IP address it got when it was created. I can’t find where that hostname is coming from. it’s not listed in /etc/hostname nor in /etc/hosts. Where to eradicate this?
I’d start over, but I’ve already done a bunch of other custom configuration stuff that I don’t want to do again.
