ubuntu intrepid repo have upgraded their libsasl2 to libsasl2-2 which is needed by virtualmin-base
below is the error code, any help on this ?[code:1]/usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
Reading package lists…
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
virtualmin-base: Depends: libsasl2 but it is not installable
FATAL - Fatal Error Occurred: Installation failed: 0
[code:1]
INFO - Installing Webmin and Virtualmin package signing keys…
2008-12-31 10:39:23 URL:http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin [1690/1690] -> “RPM-GPG-KEY-virtualmin” [1]
INFO - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
2008-12-31 10:39:24 URL:http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin [1320/1320] -> “RPM-GPG-KEY-webmin” [1]
INFO - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - OK
INFO - OK
E: Malformed line 54 in source list /etc/apt/sources.list (dist parse)
INFO -
INFO - Removing Debian standard Webmin package, if they exist (because they’re broken)…
INFO - Removing Debian apache packages…
E: The list of sources could not be read.
INFO - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip quota
…in progress, please wait…
.E: Malformed line 54 in source list /etc/apt/sources.list (dist parse)
INFO - 2008-12-31 10:39:14 - Enabling universe repositories, if not already available…
INFO - 2008-12-31 10:39:14 - Disabling cdrom repositories…
INFO - 2008-12-31 10:39:21 - Cleaning up apt headers and packages, so we can start fresh…
INFO - 2008-12-31 10:39:22 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2008-12-31 10:39:22 - Installing Webmin and Virtualmin package signing keys…
INFO - 2008-12-31 10:39:23 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2008-12-31 10:39:24 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2008-12-31 10:39:24 - OK
INFO - 2008-12-31 10:39:24 - Removing Debian standard Webmin package, if they exist (because they’re broken)…
INFO - 2008-12-31 10:39:24 - Removing Debian apache packages…
DEBUG - 2008-12-31 10:39:24 -
INFO - 2008-12-31 10:39:24 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip quota
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
Again, regular Ubuntu releases just have too short of a lifecycle for use on servers.
There may come a time in the future where Ubuntu is popular enough that I feel compelled (and have the budget for) supporting even non-LTS releases…but I will always strongly discourage their use.
As for what to do with a system that you upgraded…well, I don’t think downgrading in place is possible (or advisable). So, if a reinstall of 8.04LTS isn’t a huge ordeal, that’d be the way to go.
Otherwise, you can just treat it like a manual installation of Virtualmin. This puts more responsibilities on your plate, but it’s not an impossible situation–we all used Virtualmin that way for the first two or three years. It’s just more work for you.
Actually, I will mention that I discovered something about Debian and Ubuntu recently that should make supporting new versions of those systems somewhat easier.
This might mean I’d be willing to setup a repo for other Ubuntu releases and call them Grade B supported systems (i.e. fully supported by the installer, but discouraged, and not usable with installation or other premium support services, because of issues like short lifecycle and less stability…Fedora is in this category).
No promises on that count, though…I’m still fighting with Debian 5.0 support.
Don’t worry about the double-post, this forum is nuts and has a mind of it’s own
Regarding upgrading – before upgrading or changing distros, I’d definitely check with the OS Support page below to verify that it’s supported.
Sometimes even when distribution support is planned, it can take a couple of weeks between when a release occurs, and when it’s supported by Virtualmin.
