Here is one attempt at installing on a Xen VPS running CentOS. Any ideas on what is going wrong?
Downloading virtualmin-release package for CentOS Linux 3.5…
% Total % Received % Xferd Average Speed Time Curr.
Dload Upload Total Current Left Speed
100 10501 100 10501 0 0 101k 0 0:00:00 0:00:00 0:00:00 353k
warning: virtualmin-release-latest.noarch.rpm: V3 DSA signature: NOKEY, key ID xxxxxxxxx
Preparing… ########################################### [[100%]]
1:virtualmin-release ########################################### [[100%]]
Running updatedb so locate works…this will take a little while.
Attempting to import various system RPM-GPG-KEY files…Errors may occur,
if you’ve already imported them. It is safe to ignore these errors.
Installing dependencies using command: /usr/bin/up2date --nox postfix bind spamassassin procmail perl perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion ruby rdoc ri mysql mysql-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php mod_perl mod_python cyrus-sasl dovecot spamassassin
Fetching Obsoletes list for channel: centos-3-base…
Fetching Obsoletes list for channel: centos-3-addons…
Fetching Obsoletes list for channel: centos-3-updates…
Fetching Obsoletes list for channel: centos-3-extras…
Fetching rpm headers…
Name Version Rel
mailman 2.1.5 25.rhel3 i386
mod_python 3.0.3 5.ent i386
perl-DBD-Pg 1.21 2 i386
postfix 2.0.16 14.RHEL3 i386
rh-postgresql 7.3.10 1 i386
rh-postgresql-server 7.3.10 1 i386
ruby 1.6.8 9.EL3.4 i386
spamassassin 2.55 3.4 i386
Testing package set / solving RPM inter-dependencies…
mailman-2.1.5-25.rhel3.i386 ########################## Done.
mod_python-3.0.3-5.ent.i386 ########################## Done.
perl-DBD-Pg-1.21-2.i386.rpm ########################## Done.
postfix-2.0.16-14.RHEL3.i38 ########################## Done.
rh-postgresql-7.3.10-1.i386 ########################## Done.
rh-postgresql-server-7.3.10 ########################## Done.
ruby-1.6.8-9.EL3.4.i386.rpm ########################## Done.
spamassassin-2.55-3.4.i386. ########################## Done.
perl-Digest-HMAC-1.01-11.1. ########################## Done.
perl-Net-DNS-0.31-3.1.noarc ########################## Done.
perl-Time-HiRes-1.38-3.i386 ########################## Done.
rh-postgresql-libs-7.3.10-1 ########################## Done.
ruby-libs-1.6.8-9.EL3.4.i38 ########################## Done.
perl-Digest-SHA1-2.01-15.1. ########################## Done.
Preparing ########################################### [[100%]]
Installing…
1:rh-postgresql-libs ########################################### [[100%]]
2:rh-postgresql ########################################### [[100%]]
3:perl-Digest-SHA1 ########################################### [[100%]]
4:perl-Digest-HMAC ########################################### [[100%]]
5:perl-Net-DNS ########################################### [[100%]]
6:ruby-libs ########################################### [[100%]]
7:perl-Time-HiRes ########################################### [[100%]]
8:mailman ########################################### [[100%]]
9:mod_python ########################################### [[100%]]
10:perl-DBD-Pg ########################################### [[100%]]
11:postfix ########################################### [[100%]]
12:rh-postgresql-server ########################################### [[100%]]
13:ruby ########################################### [[100%]]
14:spamassassin ########################################### [[100%]]
The following packages were added to your selection to satisfy dependencies:
Name Version Release
perl-Digest-HMAC 1.01 11.1
perl-Net-DNS 0.31 3.1
perl-Time-HiRes 1.38 3
rh-postgresql-libs 7.3.10 1
ruby-libs 1.6.8 9.EL3.4
perl-Digest-SHA1 2.01 15.1
package_type = rpm
Installing Virtualmin and all related packages now using the command:
yum -y install virtualmin-base
Gathering header information file(s) from server(s)
Server: CentOS-3 - Addons
Server: CentOS-3 - Base
Server: CentOS-3 - Extras
Server: CentOS-3 - Updates
Server: Red Hat Enterprise 3 - i386 - Virtualmin
Server: Virtualmin Distribution Neutral
Finding updated packages
Downloading needed headers
yum-0-2.0.8-1.centos.7.vm 100% |=========================| 3.9 kB 00:00
httpd-1-2.0.46-46.rhel3.v 100% |=========================| 19 kB 00:00
mod_ssl-2-2.0.46-46.rhel3 100% |=========================| 8.1 kB 00:00
neon-devel-0-0.24.7-1.1.e 100% |=========================| 9.2 kB 00:00
scponly-debuginfo-0-4.1-1 100% |=========================| 1.5 kB 00:00
perl-Net-SSLeay-debuginfo 100% |=========================| 1.8 kB 00:00
wbt-virtualmin-nuvola-ras 100% |=========================| 20 kB 00:00
wbm-virtualmin-dav-0-2.80 100% |=========================| 2.3 kB 00:00
webmin-0-1.230-1.noarch.h 100% |=========================| 292 kB 00:00
apr-debuginfo-0-0.9.4-24. 100% |=========================| 2.7 kB 00:00
awstats-0-6.5-0.1.050822. 100% |=========================| 22 kB 00:00
httpd-debuginfo-1-2.0.46- 100% |=========================| 21 kB 00:00
apr-0-0.9.4-24.2.i386.hdr 100% |=========================| 3.2 kB 00:00
mod_fastcgi-0-2.4.2-1.vm. 100% |=========================| 1.6 kB 00:00
clamav-0-0.87-1.vm.i386.h 100% |=========================| 4.3 kB 00:00
usermin-0-1.160-1.noarch. 100% |=========================| 78 kB 00:00
mod_dav_svn-0-1.1.4-0.1.1 100% |=========================| 1.6 kB 00:00
apr-devel-0-0.9.4-24.2.i3 100% |=========================| 10 kB 00:00
wbt-virtualmin-nuvola-0-1 100% |=========================| 20 kB 00:00
clamav-devel-0-0.87-1.vm. 100% |=========================| 2.5 kB 00:00
perl-Net-SSLeay-0-1.26-2. 100% |=========================| 5.7 kB 00:00
httpd-devel-1-2.0.46-46.r 100% |=========================| 12 kB 00:00
wbm-virtualmin-awstats-0- 100% |=========================| 2.9 kB 00:00
wbt-virtualmin-nuvola-gre 100% |=========================| 20 kB 00:00
subversion-0-1.1.4-0.1.1. 100% |=========================| 7.8 kB 00:00
virtualmin-base-0-1.0-17. 100% |=========================| 4.4 kB 00:00
wbm-virtualmin-svn-0-2.80 100% |=========================| 2.8 kB 00:00
clamav-milter-0-0.87-1.vm 100% |=========================| 2.8 kB 00:00
clamd-0-0.87-1.vm.i386.hd 100% |=========================| 3.2 kB 00:00
scponly-0-4.1-1.vm.i386.h 100% |=========================| 1.9 kB 00:00
wbm-virtualmin-htpasswd-0 100% |=========================| 2.3 kB 00:00
clamav-db-0-0.87-1.vm.i38 100% |=========================| 2.5 kB 00:00
wbt-virtualmin-nuvola-pus 100% |=========================| 20 kB 00:00
subversion-devel-0-1.1.4- 100% |=========================| 3.5 kB 00:00
wbt-virtualmin-nuvola-cho 100% |=========================| 20 kB 00:00
wbt-virtualmin-nuvola-dus 100% |=========================| 20 kB 00:00
wbm-virtual-server-0-2.90 100% |=========================| 19 kB 00:00
mod_fastcgi-debuginfo-0-2 100% |=========================| 1.7 kB 00:00
ust-virtualmin-nuvola-0-1 100% |=========================| 6.9 kB 00:00
proftpd-debuginfo-0-1.2.1 100% |=========================| 2.7 kB 00:00
neon-0-0.24.7-1.1.el3.dag 100% |=========================| 1.9 kB 00:00
clamav-debuginfo-0-0.87-1 100% |=========================| 6.7 kB 00:00
proftpd-0-1.2.10-9.vm.i38 100% |=========================| 7.5 kB 00:00
wbm-virtualmin-mailman-0- 100% |=========================| 3.1 kB 00:00
Resolving dependencies
…Dependencies resolved
I will do the following:
[[install: virtualmin-base 1.0-17.rh.noarch]]
I will install/upgrade these to satisfy the dependencies:
[[deps: clamd 0.87-1.vm.i386]]
[[deps: clamav-db 0.87-1.vm.i386]]
[[deps: webmin 1.230-1.noarch]]
[[deps: usermin 1.160-1.noarch]]
[[deps: scponly 4.1-1.vm.i386]]
[[deps: clamav 0.87-1.vm.i386]]
[[deps: ust-virtualmin-nuvola 1.155-1.noarch]]
[[deps: wbt-virtualmin-nuvola-pushup 1.230-1.noarch]]
[[deps: wbt-virtualmin-nuvola 1.230-1.noarch]]
[[deps: awstats 6.5-0.1.050822.vm.noarch]]
[[deps: mod_fastcgi 2.4.2-1.vm.i386]]
[[deps: wbm-virtualmin-svn 2.80-1.noarch]]
[[deps: wbt-virtualmin-nuvola-raspberry 1.230-1.noarch]]
[[deps: wbm-virtualmin-dav 2.80-1.noarch]]
[[deps: wbm-virtualmin-htpasswd 2.80-1.noarch]]
[[deps: wbt-virtualmin-nuvola-chocmint 1.230-1.noarch]]
[[deps: wbm-virtual-server 2.90-1.noarch]]
[[deps: wbt-virtualmin-nuvola-dusk 1.230-1.noarch]]
[[deps: perl-Net-SSLeay 1.26-2.vm.i386]]
[[deps: wbt-virtualmin-nuvola-green 1.230-1.noarch]]
[[deps: proftpd 1.2.10-9.vm.i386]]
[[deps: wbm-virtualmin-awstats 2.80-1.noarch]]
[[deps: wbm-virtualmin-mailman 2.80-1.noarch]]
Downloading Packages
Getting clamd-0.87-1.vm.i386.rpm
clamd-0.87-1.vm.i386.rpm 100% |=========================| 58 kB 00:00
Getting clamav-db-0.87-1.vm.i386.rpm
clamav-db-0.87-1.vm.i386. 100% |=========================| 2.5 MB 00:03
Getting webmin-1.230-1.noarch.rpm
webmin-1.230-1.noarch.rpm 100% |=========================| 9.1 MB 00:12
Getting usermin-1.160-1.noarch.rpm
usermin-1.160-1.noarch.rp 100% |=========================| 2.8 MB 00:04
Getting scponly-4.1-1.vm.i386.rpm
scponly-4.1-1.vm.i386.rpm 100% |=========================| 22 kB 00:00
Getting clamav-0.87-1.vm.i386.rpm
clamav-0.87-1.vm.i386.rpm 100% |=========================| 605 kB 00:00
Getting ust-virtualmin-nuvola-1.155-1.noarch.rpm
ust-virtualmin-nuvola-1.1 100% |=========================| 286 kB 00:00
Getting wbt-virtualmin-nuvola-pushup-1.230-1.noarch.rpm
wbt-virtualmin-nuvola-pus 100% |=========================| 1.9 MB 00:02
Getting wbt-virtualmin-nuvola-1.230-1.noarch.rpm
wbt-virtualmin-nuvola-1.2 100% |=========================| 1.9 MB 00:02
Getting awstats-6.5-0.1.050822.vm.noarch.rpm
awstats-6.5-0.1.050822.vm 100% |=========================| 1.0 MB 00:00
Getting mod_fastcgi-2.4.2-1.vm.i386.rpm
mod_fastcgi-2.4.2-1.vm.i3 100% |=========================| 35 kB 00:00
Getting wbm-virtualmin-svn-2.80-1.noarch.rpm
wbm-virtualmin-svn-2.80-1 100% |=========================| 20 kB 00:00
Getting wbt-virtualmin-nuvola-raspberry-1.230-1.noarch.rpm
wbt-virtualmin-nuvola-ras 100% |=========================| 1.9 MB 00:02
Getting wbm-virtualmin-dav-2.80-1.noarch.rpm
wbm-virtualmin-dav-2.80-1 100% |=========================| 10 kB 00:00
Getting virtualmin-base-1.0-17.rh.noarch.rpm
virtualmin-base-1.0-17.rh 100% |=========================| 12 kB 00:00
Getting wbm-virtualmin-htpasswd-2.80-1.noarch.rpm
wbm-virtualmin-htpasswd-2 100% |=========================| 7.9 kB 00:00
Getting wbt-virtualmin-nuvola-chocmint-1.230-1.noarch.rpm
wbt-virtualmin-nuvola-cho 100% |=========================| 1.9 MB 00:01
Getting wbm-virtual-server-2.90-1.noarch.rpm
wbm-virtual-server-2.90-1 100% |=========================| 491 kB 00:00
Getting wbt-virtualmin-nuvola-dusk-1.230-1.noarch.rpm
wbt-virtualmin-nuvola-dus 100% |=========================| 1.9 MB 00:02
Getting perl-Net-SSLeay-1.26-2.vm.i386.rpm
perl-Net-SSLeay-1.26-2.vm 100% |=========================| 190 kB 00:00
Getting wbt-virtualmin-nuvola-green-1.230-1.noarch.rpm
wbt-virtualmin-nuvola-gre 100% |=========================| 1.9 MB 00:01
error: rpmts_HdrFromFdno: V3 DSA signature: BAD, key ID xxxxxxxxx
Error Reading Header on /var/cache/yum/virtualmin-universal/packages/wbt-virtualmin-nuvola-green-1.230-1.noarch.rpm
Error: You may want to run yum clean or remove the file:
Installation failed: 1
Removing virtualmin-release package, so that installation can be re-attempted
after any problems reported are resolved.
cp: cannot stat `/usr/libexec/webmin/virtualmin-mailman/config-redhat-linux’: No such file or directory
I removed the Key ID from this listing although it says something about it being bad and I have tried this a couple of times before and have never gotten dovecot to install even when I was able to get past this point with an earlier version of the installer.
TIA!
