| SYSTEM INFORMATION | |
| OS type and version | Debian linux 9 |
| Webmin version | 1.994 |
| Virtualmin version | 7.1-1 |
| Related packages | Mariadb 10.1.48 |
I have php 7.4 and using 12gb ram on my server with only one website.
i have those config files as you can see in dropdown.
And only config file which contains some correct config details i can see this one (second screenshot)
My problem is when i add:
innodb_buffer_pool_size=3GB
Right before the key_buffer size and restart the maridb getting error and server dont starting at all.
I have tried to put it on all other config files but got same error.
how can i chnage that standart 128M poolsize?
