I’ve been playing around with Xen images and wanted to share my experiences, some issues I’ve run into & some feature requests for Cloudmin.
Some background info on my dom0:
- Intel Xeon’s
- Kernel 2.6.29 with rebased OpenSUSE Xen patches
- Xen 3.4.0
- x86_64
- Gentoo (Funtoo)
Kernel & Initrd
When I build my kernels I build two different kernels, one for dom0 & one for domU’s.
The way that kernel & initrd images are handled doesn’t work too well outside of CentOS/Debian (from reading the code). I don’t use initrd’s, I have a homogenous hardware environment so my required drivers are compiled into the kernel and I use modules for things like USB devices, IPTables/LVS, etc. As such when I tried to setup the Xen dom0 system in cloudmin it bombed out trying to create an initrd initially (mkinitrd wasn’t even installed on my system), once I installed mkinitrd it bombed out because the xenblk module isn’t available (because it’s compiled in) so I poked around in xen-type-lib, created an initrd by hand and put it in /boot as the filename that cloudmin was looking for.
I would really love to see some better options for handling Kernels & Initrd on Xen dom0’s. Maybe enumerate /boot on the dom0 and allow the user to pick a kernel & initrd for each guest on creation as opposed to tying it to dom0. This would also allow a dom0 to contain multiple domU kernels to be used.
On the same topic, pygrub support would nice to see in the future so that domU’s can boot of their own kernels.
Network Interfaces
On my Xen dom0 I have two bridges, one carries production traffic the other carries traffic to my NAS. When I create an image with Cloudmin I can only specify the config for one interface. I manually edited the config file and added a second instance to the vif statement with the correct bridge tags. Looking through the options I’m guessing at this point in time my best bet is to use the post modification scripts to set this up for new images. Any chance we could get some more flexible network config options built into Cloudmin?
One thing I would really love to see is the addition of tying IP blocks defined on a dom0 to a particular bridge, thus I could auto allocate from each block for each device.
Xen Config Templates / SCSI device ids
When Cloudmin creates a Xen system it uses ‘sdaX’ as the device IDs. This causes the guest in my environment to display the ever annoying “XENBUS: waiting for devices to initialize” message and then spend 5 minutes counting down to 0 at which point it boots normally. I can work around this by disabling SCSI support in my kernel but due to option dependancy this is less than desirable.
Changing the device ID for the guest from ‘sdaX’ to ‘xvdaX’ skips the waiting message and the guest boots like normal. Like the network interfaces it’s possible to edit the config file (and hosts fstab) by hand afterwards, I could also built this into a post modification script, but it seems to make sense to either have this as a configurable option in Cloudmin or at least provide an easy way to edit a template from which the Guest configs are generated so I don’t have to go mucking around in xen-type-lib.pl.
Cloudmin system as Xen guest
My Cloudmin install is running inside a Xen guest on a dom0 I wish to manage. When I try to “Find Xen instances” I get the message: The system X.fatbox.ca is already using IP address X.X.X.X
Not a huge deal but it would be nice if Cloudmin could recognize that it’s inside a guest and allow for further management (reboots, resources, etc).
SSH Host Key’s on repeat installs
If you create a guest, have it come up and generate SSH host keys, delete it and then re-create a new guest that is assigned the same IP you get an error in Last Status about SSH and the detailed status shows all ‘@@@…’ because SSH is returning the error about the host keys changing. When a system is deleted Cloudmin should purge the SSH keys for it from ~root/.ssh/known_hosts
System image caching on dom0’s
Most of the dom0’s I’m managing are in the same data center as the cloudmin instance on a gigabit network so moving images around when creating instances isn’t a big deal, but one of the systems I have under the control of cloudmin is back at my office and while it has a 10mb pipe (100mb out of the DC) the transfer still takes some time and eats up bandwidth (contributing to my 95th percentile). I would love to see some type of caching so that once I’ve transfered an image it will remain on the dom0 system until the image is updated on the cloudmin system.
I’ll be continuing to play with cloudmin over the weekend and will post anything else I come across in this topic.
So far I’m quite pleased with cloudmin. It’s shaping up to be a great tool
