I have a problem with LetsEncrypt SSL certificate. Virtualmin has setup the certificate and reports it installed OK but when visiting the site browsers warn that the certificate is wrong, they are seeing a certificate for the first virtual host not the correct one for the domain. You can see the example at https://grantbentleyandassociates.com/ it lists the certificate as acupuncturemooroolbark.com
You’ve likely got one or more VirtualHost sections with *:443, while others have 192.168.1.1:443 (where 192.168.1.1 is your IP). That can cause weird behavior…Apache understands how it decides what to serve, but nobody else can.
I had the same problem and am posting here because this is the most recent thread to describe the problem. My resolution was different.
I have several IP’s on my virtualmin instance. What I found was that the site was bound to IP 1, while DNS was pointing people to IP 2. Once I updated the domain config within virtualmin to match what DNS was pointing to, the correct SSL certificate was served.
To clarify, this apparently never caused a problem over http, so this misconfiguration was missed for several months.
