| SYSTEM INFORMATION||
| SYSTEM INFORMATION | |
| OS type and version | Ubuntu Linux 18.04.6 |
| Usermin version | 2.102 |
| Virtualmin version | 7.30.3 Pro |
| Theme version | 21.20.7 |
| Apache version | 2.4.29 |
| Package updates | All installed packages are up to date |
System shows a missing “.” in the IP of server to update where can this be corrected
When I try to correct the issue here
I get Failed to change IP Address: Missing or invalid old address
I deleted the one play VM and looked at this same location and it show the correct IP
So I go back and recheck configuration it shows the wrong IP again and says system is ready for use, return to virtual servers and says systems primary address appears to have changed from the old one to the new one, then select Update Incorrect IP addess and get the same error message
Keith
