Ich habe probleme mit der konfiguration von IMAP und SMTP…
Über usermin klappt der E-Mail versand… die DNS zonen sind richtig konfiruiert und das SSL Zertifikat auch aktuell… jedoch kann ich leider keinen Imap account in z.B Aplle Iphone anlegen…
You might get more help if you use a translation service.
I’m having problems configuring IMAP and SMTP…
Sending emails works via usermin… the DNS zones are correctly configured and the SSL certificate is also up to date… but unfortunately I can’t create an Imap account in e.g. Apple iPhone…
I suggested they put this info into Usermin for the end users, but I see it never made it.
Under Edit Users in the Virtualmin domain, towards the bottom is:
Show Email Client Settings. Should have everything you need to set up the account on the phone.
Is this a new server or has it been up and functioning for awhile?
Do other external clients other than the iPhone work OK?
I’m pretty much out of guesses. Have you checked things in this module?
It’s a new server … normally I work with Plesk 2 from 3 Server Running with Plesk and now I want to find out more about Virtualmin and when it’s works on my testserver where I use it … I will change my other servers to Virtualmin too …
I have the same options on my Settings … thanks for that … but it doesn’t fix it …
