I have several domains running on this server and when I check the SSL for validity all of them seem to work just fine except for one! I think I have all the settings the same on them… but It’s also possible I may have accidentally made a mistake!
Here is the error I get when I run the SSL Verification on this domain… stjohnscatfishfest.com (38.40.66.166) has the correct chain.
As I said… I’m using one of my domains as a nameserver. Every other domain on that server is correct and they are all using the same nameserver. So I have no idea where the problem may be. Should I reissue the SSL? Could the problem be there?
you have a problem with the wrong IPV6 address, you need to correct that which will be done at the DNS server (where ever it is).
If virtualmin is maintaining your dns, it will be a case of just adjusting that record to suit the correct IPV6 address with in the virtualmin GUI if not you need to edit the record at where ever the DNS is maintained.
getting a new cert will not help you in this case, editing the DNS records will
Virtualmin is maintaining my DNS. And in the DNS Settings it says the IPv6 address is: 2606:9cc0:300:2de:20c:29ff:fe53:b4c2 the DNS tester is picking up 2606:9cc0:300:d1:20c:29ff:fe53:b4c2 which in the “Allowed Sender” area. Should I change the address in the allowed sender area to 2606:9cc0:300:2de:20c:29ff:fe53:b4c2
