There’s nothing useful to test, IMHO. Web servers are plenty fast. It’s always the apps that are slow. Apache needs a little more memory, but performance is fine…it can serve thousands of requests per second on the tiniest machine you could rent for hosting today. Nobody running Virtualmin is serving thousands of requests per second (that tens or hundreds of millions of requests a day), to hundreds of connected clients, with excellent latency.
If you’re worrying about Apache performance beyond the basics (don’t use/load mod_php, use an efficient MPM rather than prefork, which is another reason to not load mod_php because it forces prefork), you’re spending time on the wrong thing. If you saw a “slow” Apache it was an Apache with mod_php loaded or explicitly configured to use prefork MPM. But, even that isn’t slow enough to matter compared to what any application written in dynamic languages like PHP, JavaScript, Perl, Python, Ruby, etc. can do. Your apps are literally orders of magnitude slower than Apache. Unless you’re only serving static sites and you have crazy traffic with millions of daily visitors, you almost certainly should spend your time optimizing literally everything else before you even start thinking about the web server.
And, if you want to run nginx, just run nginx. It’s silly to run two web servers, and more than negates the one clear benefit of running nginx. The smaller memory footprint of nginx is the one thing about nginx I think is worth seriously considering, if you’re running on modest hardware…performance is irrelevant at the scale we’re all talking about. Running Apache+nginx removes that benefit and means you need more memory than Apache alone. I’m sorry, that’s just an obviously bad idea. Running a proxy also adds another hop of latency! You make your requests to Apache slower by running nginx in front; it’s by a small amount, but if you’re willing to jump through crazy hoops to get a tiny performance boost for static files, it’s silly to hurt performance of your dynamic pages by a similar margin. Not to mention, static assets can be cached at the edge (in the browser, in Cloudflare/Fastly/etc.), dynamic pages cannot. You’re optimizing the exact wrong things if you’re optimizing static assets at the expense of dynamic ones.
In short: The reason to pick nginx when you might prefer the flexibility of Apache is when you’re running on a resource-constrained system (i.e. low memory). Running two web servers on a resource-constrained system is a bad idea. I can’t imagine how that is controversial or something people seriously discuss as some kind of rational option, I honestly don’t know. I won’t be part of a silly waste of resources like that, not to mention the wasted human time on maintaining multiple web servers for no danged reason.
Also, unrelated to nginx or performance, it looks like some of y’all have the impression fcgiwrap is for running fcgi applications. That’s not so. nginx supports fcgi natively, as does Apache. fcgiwrap is for running CGI applications (CGI is a completely different protocol from FCGI), and we now use it on both nginx and Apache because even though Apache has native support for CGI applications, we no longer build a custom Apache that has suexec_docroot set to /home on EL systems. fcgiwrap allows us to run CGI scripts as the domain owner user for both Apache and nginx.
