I need help configuring my hosting DNS to redirect an existing domain to a Shopify store.
I can’t find the DNS settings option in the control panel.
I’d be happy to assist, drop me a line when you have a moment.
DNS does not redirect. Web servers can redirect.
But, you can change the DNS record to point anywhere you want them to, if your Virtualmin server is managing DNS. To edit DNS records, select the domain, then click Server Configuration->DNS Records
Note that this might break the ability of Virtualmin to request SSL certs from Let’s Encrypt, depending on what domain(s) you change and which domains you’re getting certs for.
