I have a serious problem… I have a working mail server, but the web server does not work at all… for example, I put an index.php or index.html file in the public_html subdirectory of my website directory, and nothing happened… I mean, when I then go to http://www.mywebsite.com, nothing… it says there is no website there…
Possibly a problem with the NameVirtualHost and VirtualHost sections. The IP for both has to match, or the "default" site will be served for everything.
But that is the problem. Even the default server do not work. No server works.
And btw when I keep the virtualmin config as it is, when i restart apache I have the error message :
"* Apache2 has detected a syntax error in your configuration files:
/etc/init.d/apache2: line 23: 3255 Erreur de segmentation ${APACHE2} ${APACHE2_OPTS} -t"
I look at the config file, and it shows :
"VirtualHost xxx.xxx.xxx.xxx:80>" in the first line.
If I replace it by “<VirtualHost>” without the IP, I can restart apache without error but… I can’t access my website either.
