I can'r receive Emails from out side
OS type and version: Ubuntu 20.4
Webmin version: 1.981
Virtualmin version: 6.17-3
Related products version: Postfix 3.4.13
after updating postfix I can’t receive any emails from outside like gmail or outlook …etc
how I can reset postfix configuration to default or fix it?
the mail.log message:
Oct 5 18:47:48 ns1 postfix/smtpd[87528]: NOQUEUE: reject: RCPT from mail2.odoo.com[149.202.180.44]: 451 4.3.5 <odoo@mydomain.com>: Recipient address rejected: Server configuration problem; from=<bounce+102343518-event.registration-675570@mail.odoo.com> to=<odoo@mydomain.com> proto=ESMTP helo=<mail2.odoo.com>
I would temporarily increase the verbosity of logging and tail -fn 200 mail.log while watching an incoming email transaction. Also restart Postfix from the commandline or Web UI and watch the logs. You can also specify a custom maillog path.
Did you just run apt-get upgrade and have you added any third-party repositories? Have you altered your postfix config files, or imported lots of settings which used to work in an older Postfix version? If you have jumped many versions with the upgrade then you may find some of the config variables are deprecated with the new version of Postfix.
Posting your main.cf and master.cf (or postconf -n) may be helpful.
 root@ns1:~# postconf -n
append_dot_mydomain = yes
biff = no
compatibility_level = 2
home_mailbox = Maildir/
inet_protocols = all
mailbox_size_limit = 0
milter_default_action = accept
mydestination = $myhostname, localhost.$mydomain, $mydomain, ns1.systemscart.com, localhost.contaboserver.net, localhost
mynetworks_style = subnet
non_smtpd_milters = inet:localhost:8891
readme_directory = no
recipient_delimiter = +
sender_dependent_default_transport_maps = hash:/etc/postfix/dependent
smtp_dns_support_level = dnssec
smtp_host_lookup = dns
smtp_tls_CApath = /etc/ssl/certs
smtp_tls_security_level = dane
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
smtpd_recipient_restrictions = permit_mynetworks permit_sasl_authenticated reject_unauth_destination check_policy_service inet:127.0.0.1:10023
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
smtpd_sasl_auth_enable = yes
smtpd_tls_CAfile = /etc/postfix/postfix.ca.pem
smtpd_tls_cert_file = /etc/postfix/postfix.cert.pem
smtpd_tls_key_file = /etc/postfix/postfix.key.pem
smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3, !TLSv1, !TLSv1.1
smtpd_tls_security_level = may
tls_server_sni_maps = hash:/etc/postfix/sni_map
Oct  6 23:39:22 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:39:25 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:39:30 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:39:37 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:39:43 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:39:49 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:39:56 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:40:02 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:40:09 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:40:15 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:40:22 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:40:29 ns1 postfix/smtpd[226805]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:40:31 ns1 postfix/smtpd[226805]: too many errors after AUTH from unknown[74.201.28.92]
Oct  6 23:40:31 ns1 postfix/smtpd[226805]: disconnect from unknown[74.201.28.92] ehlo=1 auth=0/20 rset=20 commands=21/41
Oct  6 23:41:49 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=226898, TLS, session=<TEJ3A7bNnqmsEQAQ>
Oct  6 23:41:49 ns1 dovecot: imap(hello@systemscart.com)<226898><TEJ3A7bNnqmsEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  6 23:43:51 ns1 postfix/anvil[226807]: statistics: max connection rate 1/60s for (smtp:74.201.28.92) at Oct  6 23:39:01
Oct  6 23:43:51 ns1 postfix/anvil[226807]: statistics: max connection count 1 for (smtp:74.201.28.92) at Oct  6 23:39:01
Oct  6 23:43:51 ns1 postfix/anvil[226807]: statistics: max cache size 1 at Oct  6 23:39:01
Oct  6 23:45:22 ns1 postfix/smtpd[227177]: connect from unknown[103.167.92.100]
Oct  6 23:45:25 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:28 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:32 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:35 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:35 ns1 postfix/smtpd[227186]: connect from unknown[103.167.92.100]
Oct  6 23:45:38 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:38 ns1 postfix/smtpd[227186]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:39 ns1 postfix/smtpd[227186]: disconnect from unknown[103.167.92.100] ehlo=1 auth=0/1 quit=1 commands=2/3
Oct  6 23:45:42 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:45 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:48 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:51 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:45:54 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:00 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:07 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:15 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:22 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:29 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:37 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:44 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:51 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:46:54 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=227216, TLS, session=<t8yqFbbN7KmsEQAQ>
Oct  6 23:46:54 ns1 dovecot: imap(hello@systemscart.com)<227216><t8yqFbbN7KmsEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  6 23:46:59 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:47:06 ns1 postfix/smtpd[227177]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:47:08 ns1 postfix/smtpd[227177]: too many errors after AUTH from unknown[103.167.92.100]
Oct  6 23:47:08 ns1 postfix/smtpd[227177]: disconnect from unknown[103.167.92.100] ehlo=1 auth=0/20 rset=20 commands=21/41
Oct  6 23:47:36 ns1 postfix/smtpd[227177]: connect from mailsaas4.odoo.com[195.154.60.200]
Oct  6 23:47:36 ns1 postfix/trivial-rewrite[227383]: warning: do not list domain systemscart.com in BOTH mydestination and virtual_alias_domains
Oct  6 23:47:36 ns1 postfix/smtpd[227177]: warning: connect to 127.0.0.1:10023: Connection refused
Oct  6 23:47:36 ns1 postfix/smtpd[227177]: warning: problem talking to server 127.0.0.1:10023: Connection refused
Oct  6 23:47:37 ns1 postfix/smtpd[227177]: warning: connect to 127.0.0.1:10023: Connection refused
Oct  6 23:47:37 ns1 postfix/smtpd[227177]: warning: problem talking to server 127.0.0.1:10023: Connection refused
Oct  6 23:47:37 ns1 postfix/smtpd[227177]: NOQUEUE: reject: RCPT from mailsaas4.odoo.com[195.154.60.200]: 451 4.3.5 <odoo@systemscart.com>: Recipient address rejected: Server configuration problem; from=<bounce+102434258-event.registration-675570@mail.odoo.com> to=<odoo@systemscart.com> proto=ESMTP helo=<mailsaas5.odoo.com>
Oct  6 23:47:37 ns1 postfix/smtpd[227177]: disconnect from mailsaas4.odoo.com[195.154.60.200] ehlo=2 starttls=1 mail=1 rcpt=0/1 data=0/1 rset=1 quit=1 commands=6/8
Oct  6 23:47:42 ns1 postfix/smtpd[227177]: connect from ams1-001.global.ingenico.com[185.8.55.192]
Oct  6 23:47:42 ns1 postfix/trivial-rewrite[227383]: warning: do not list domain systemscart.com in BOTH mydestination and virtual_alias_domains
Oct  6 23:47:42 ns1 postfix/smtpd[227177]: warning: connect to 127.0.0.1:10023: Connection refused
Oct  6 23:47:42 ns1 postfix/smtpd[227177]: warning: problem talking to server 127.0.0.1:10023: Connection refused
Oct  6 23:47:43 ns1 postfix/smtpd[227177]: warning: connect to 127.0.0.1:10023: Connection refused
Oct  6 23:47:43 ns1 postfix/smtpd[227177]: warning: problem talking to server 127.0.0.1:10023: Connection refused
Oct  6 23:47:43 ns1 postfix/smtpd[227177]: NOQUEUE: reject: RCPT from ams1-001.global.ingenico.com[185.8.55.192]: 451 4.3.5 <odoo@systemscart.com>: Recipient address rejected: Server configuration problem; from=<no-reply@global.ingenico.com> to=<odoo@systemscart.com> proto=ESMTP helo=<f9bc926c651b0d71644f6fce8ab82150.global.ingenico.com>
Oct  6 23:47:43 ns1 postfix/smtpd[227177]: disconnect from ams1-001.global.ingenico.com[185.8.55.192] ehlo=2 starttls=1 mail=1 rcpt=0/1 data=0/1 rset=1 quit=1 commands=6/8
Oct  6 23:51:04 ns1 postfix/anvil[227179]: statistics: max connection rate 2/60s for (smtp:103.167.92.100) at Oct  6 23:45:35
Oct  6 23:51:04 ns1 postfix/anvil[227179]: statistics: max connection count 2 for (smtp:103.167.92.100) at Oct  6 23:45:35
Oct  6 23:51:04 ns1 postfix/anvil[227179]: statistics: max cache size 3 at Oct  6 23:47:42
Oct  6 23:52:00 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=227544, TLS, session=<ntvdJ7bNgKqsEQAQ>
Oct  6 23:52:00 ns1 dovecot: imap(hello@systemscart.com)<227544><ntvdJ7bNgKqsEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  6 23:57:03 ns1 postfix/smtpd[227958]: connect from unknown[103.167.92.100]
Oct  6 23:57:05 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=228012, TLS, session=<48gSOrbNCKusEQAQ>
Oct  6 23:57:05 ns1 dovecot: imap(hello@systemscart.com)<228012><48gSOrbNCKusEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  6 23:57:06 ns1 postfix/smtpd[227958]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  6 23:57:06 ns1 postfix/smtpd[227958]: disconnect from unknown[103.167.92.100] ehlo=1 auth=0/1 quit=1 commands=2/3
Oct  6 23:57:47 ns1 postfix/smtpd[227958]: connect from mail2.odoo.com[149.202.180.44]
Oct  6 23:57:47 ns1 postfix/trivial-rewrite[228043]: warning: do not list domain systemscart.com in BOTH mydestination and virtual_alias_domains
Oct  6 23:57:47 ns1 postfix/smtpd[227958]: warning: connect to 127.0.0.1:10023: Connection refused
Oct  6 23:57:47 ns1 postfix/smtpd[227958]: warning: problem talking to server 127.0.0.1:10023: Connection refused
Oct  6 23:57:48 ns1 postfix/smtpd[227958]: warning: connect to 127.0.0.1:10023: Connection refused
Oct  6 23:57:48 ns1 postfix/smtpd[227958]: warning: problem talking to server 127.0.0.1:10023: Connection refused
Oct  6 23:57:48 ns1 postfix/smtpd[227958]: NOQUEUE: reject: RCPT from mail2.odoo.com[149.202.180.44]: 451 4.3.5 <odoo@systemscart.com>: Recipient address rejected: Server configuration problem; from=<bounce+102518536-res.partner-3932230@mail.odoo.com> to=<odoo@systemscart.com> proto=ESMTP helo=<mail2.odoo.com>
Oct  6 23:57:48 ns1 postfix/smtpd[227958]: disconnect from mail2.odoo.com[149.202.180.44] ehlo=2 starttls=1 mail=1 rcpt=0/1 data=0/1 rset=1 quit=1 commands=6/8
Oct  6 23:58:14 ns1 postfix/smtpd[227958]: warning: hostname 107-173-141-112-host.colocrossing.com does not resolve to address 107.173.141.112
Oct  6 23:58:14 ns1 postfix/smtpd[227958]: connect from unknown[107.173.141.112]
Oct  6 23:58:15 ns1 postfix/smtpd[227958]: NOQUEUE: reject: RCPT from unknown[107.173.141.112]: 554 5.7.1 <validxxxg@superproxy.com.br>: Relay access denied; from=<geyfg@hotmail.com> to=<validxxxg@superproxy.com.br> proto=ESMTP helo=<mail.systemscart.com>
Oct  6 23:58:15 ns1 postfix/smtpd[227958]: lost connection after RCPT from unknown[107.173.141.112]
Oct  6 23:58:15 ns1 postfix/smtpd[227958]: disconnect from unknown[107.173.141.112] ehlo=1 mail=1 rcpt=0/1 rset=1 commands=3/4
Oct  7 00:01:35 ns1 postfix/anvil[227961]: statistics: max connection rate 1/60s for (smtp:103.167.92.100) at Oct  6 23:57:03
Oct  7 00:01:35 ns1 postfix/anvil[227961]: statistics: max connection count 1 for (smtp:103.167.92.100) at Oct  6 23:57:03
Oct  7 00:01:35 ns1 postfix/anvil[227961]: statistics: max cache size 2 at Oct  6 23:57:47
Oct  7 00:02:10 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=228380, TLS, session=<lFpETLbN3KusEQAQ>
Oct  7 00:02:10 ns1 dovecot: imap(hello@systemscart.com)<228380><lFpETLbN3KusEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  7 00:07:16 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=228709, TLS, session=<W7Z4XrbN8KusEQAQ>
Oct  7 00:07:16 ns1 dovecot: imap(hello@systemscart.com)<228709><W7Z4XrbN8KusEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  7 00:07:57 ns1 postfix/smtpd[228728]: warning: hostname anthony.impactflower.com does not resolve to address 74.201.28.92
Oct  7 00:07:57 ns1 postfix/smtpd[228728]: connect from unknown[74.201.28.92]
Oct  7 00:07:59 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:02 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:05 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:08 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:11 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:12 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:16 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:17 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:20 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:25 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:32 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:36 ns1 postfix/smtpd[228748]: connect from unknown[103.167.92.100]
Oct  7 00:08:38 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:39 ns1 postfix/smtpd[228748]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:40 ns1 postfix/smtpd[228748]: disconnect from unknown[103.167.92.100] ehlo=1 auth=0/1 quit=1 commands=2/3
Oct  7 00:08:44 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:51 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:08:57 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:09:04 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:09:10 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:09:17 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:09:23 ns1 postfix/smtpd[228728]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:09:25 ns1 postfix/smtpd[228728]: too many errors after AUTH from unknown[74.201.28.92]
Oct  7 00:09:25 ns1 postfix/smtpd[228728]: disconnect from unknown[74.201.28.92] ehlo=1 auth=0/20 rset=20 commands=21/41
Oct  7 00:12:21 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=229107, TLS, session=<jhmscLbNNqysEQAQ>
Oct  7 00:12:21 ns1 dovecot: imap(hello@systemscart.com)<229107><jhmscLbNNqysEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  7 00:12:45 ns1 postfix/anvil[228730]: statistics: max connection rate 1/60s for (smtp:74.201.28.92) at Oct  7 00:07:57
Oct  7 00:12:45 ns1 postfix/anvil[228730]: statistics: max connection count 1 for (smtp:74.201.28.92) at Oct  7 00:07:57
Oct  7 00:12:45 ns1 postfix/anvil[228730]: statistics: max cache size 2 at Oct  7 00:08:36
Oct  7 00:13:32 ns1 dovecot: pop3-login: Login: user=<odoo@systemscart.com>, method=PLAIN, rip=209.85.221.30, lip=213.136.87.29, mpid=229133, session=<fcHddLbNIJDRVd0e>
Oct  7 00:13:32 ns1 dovecot: pop3(odoo@systemscart.com)<229133><fcHddLbNIJDRVd0e>: Disconnected: Logged out top=0/0, retr=0/0, del=0/20, size=2053904
Oct  7 00:17:27 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=229423, TLS, session=<H//fgrbNbKysEQAQ>
Oct  7 00:17:27 ns1 dovecot: imap(hello@systemscart.com)<229423><H//fgrbNbKysEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  7 00:20:09 ns1 postfix/smtpd[229503]: connect from unknown[103.167.92.100]
Oct  7 00:20:12 ns1 postfix/smtpd[229503]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:20:12 ns1 postfix/smtpd[229503]: disconnect from unknown[103.167.92.100] ehlo=1 auth=0/1 quit=1 commands=2/3
Oct  7 00:22:32 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=229741, TLS, session=<HmQSlbbNeqysEQAQ>
Oct  7 00:22:32 ns1 dovecot: imap(hello@systemscart.com)<229741><HmQSlbbNeqysEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  7 00:23:32 ns1 postfix/anvil[229505]: statistics: max connection rate 1/60s for (smtp:103.167.92.100) at Oct  7 00:20:09
Oct  7 00:23:32 ns1 postfix/anvil[229505]: statistics: max connection count 1 for (smtp:103.167.92.100) at Oct  7 00:20:09
Oct  7 00:23:32 ns1 postfix/anvil[229505]: statistics: max cache size 1 at Oct  7 00:20:09
Oct  7 00:26:32 ns1 postfix/smtpd[229874]: connect from unknown[164.52.24.168]
Oct  7 00:26:32 ns1 postfix/smtpd[229874]: lost connection after CONNECT from unknown[164.52.24.168]
Oct  7 00:26:32 ns1 postfix/smtpd[229874]: disconnect from unknown[164.52.24.168] commands=0/0
Oct  7 00:26:36 ns1 postfix/smtpd[229882]: connect from unknown[164.52.24.168]
Oct  7 00:26:36 ns1 postfix/smtpd[229882]: lost connection after CONNECT from unknown[164.52.24.168]
Oct  7 00:26:36 ns1 postfix/smtpd[229882]: disconnect from unknown[164.52.24.168] commands=0/0
Oct  7 00:26:36 ns1 postfix/smtpd[229885]: connect from unknown[164.52.24.168]
Oct  7 00:26:36 ns1 postfix/smtpd[229874]: connect from unknown[164.52.24.168]
Oct  7 00:26:36 ns1 postfix/smtpd[229874]: lost connection after CONNECT from unknown[164.52.24.168]
Oct  7 00:26:36 ns1 postfix/smtpd[229874]: disconnect from unknown[164.52.24.168] commands=0/0
Oct  7 00:26:37 ns1 postfix/smtpd[229885]: lost connection after CONNECT from unknown[164.52.24.168]
Oct  7 00:26:37 ns1 postfix/smtpd[229885]: disconnect from unknown[164.52.24.168] commands=0/0
Oct  7 00:26:37 ns1 postfix/smtpd[229882]: connect from unknown[164.52.24.168]
Oct  7 00:26:40 ns1 postfix/smtpd[229882]: lost connection after CONNECT from unknown[164.52.24.168]
Oct  7 00:26:40 ns1 postfix/smtpd[229882]: disconnect from unknown[164.52.24.168] commands=0/0
Oct  7 00:27:37 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=230062, TLS, session=<DLhHp7bNbK2sEQAQ>
Oct  7 00:27:37 ns1 dovecot: imap(hello@systemscart.com)<230062><DLhHp7bNbK2sEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  7 00:30:00 ns1 postfix/anvil[229883]: statistics: max connection rate 5/60s for (smtp:164.52.24.168) at Oct  7 00:26:37
Oct  7 00:30:00 ns1 postfix/anvil[229883]: statistics: max connection count 2 for (smtp:164.52.24.168) at Oct  7 00:26:36
Oct  7 00:30:00 ns1 postfix/anvil[229883]: statistics: max cache size 1 at Oct  7 00:26:32
Oct  7 00:30:03 ns1 postfix/smtpd[230452]: warning: hostname starttls-virginia.proxy-research.com does not resolve to address 34.227.19.103
Oct  7 00:30:03 ns1 postfix/smtpd[230452]: connect from unknown[34.227.19.103]
Oct  7 00:30:03 ns1 postfix/smtpd[230452]: disconnect from unknown[34.227.19.103] ehlo=2 starttls=1 quit=1 commands=4
Oct  7 00:31:21 ns1 postfix/smtpd[230452]: warning: hostname starttls-virginia.proxy-research.com does not resolve to address 34.227.19.103
Oct  7 00:31:21 ns1 postfix/smtpd[230452]: connect from unknown[34.227.19.103]
Oct  7 00:31:21 ns1 postfix/smtpd[230452]: disconnect from unknown[34.227.19.103] ehlo=2 starttls=1 quit=1 commands=4
Oct  7 00:32:14 ns1 postfix/smtpd[230973]: connect from unknown[103.167.92.100]
Oct  7 00:32:18 ns1 postfix/smtpd[230973]: warning: unknown[103.167.92.100]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:32:18 ns1 postfix/smtpd[230973]: disconnect from unknown[103.167.92.100] ehlo=1 auth=0/1 quit=1 commands=2/3
Oct  7 00:32:43 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=231012, TLS, session=<c0l7ubbNwK2sEQAQ>
Oct  7 00:32:43 ns1 dovecot: imap(hello@systemscart.com)<231012><c0l7ubbNwK2sEQAQ>: Logged out in=68 out=881 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  7 00:33:06 ns1 postfix/smtpd[230973]: warning: hostname starttls-virginia.proxy-research.com does not resolve to address 34.227.19.103
Oct  7 00:33:06 ns1 postfix/smtpd[230973]: connect from unknown[34.227.19.103]
Oct  7 00:33:07 ns1 postfix/smtpd[230973]: disconnect from unknown[34.227.19.103] ehlo=2 starttls=1 quit=1 commands=4
Oct  7 00:35:49 ns1 postfix/smtpd[232288]: warning: hostname starttls-virginia.proxy-research.com does not resolve to address 34.227.19.103
Oct  7 00:35:49 ns1 postfix/smtpd[232288]: connect from unknown[34.227.19.103]
Oct  7 00:35:50 ns1 postfix/smtpd[232288]: disconnect from unknown[34.227.19.103] ehlo=2 starttls=1 quit=1 commands=4
Oct  7 00:36:44 ns1 postfix/smtpd[232288]: warning: hostname anthony.impactflower.com does not resolve to address 74.201.28.92
Oct  7 00:36:44 ns1 postfix/smtpd[232288]: connect from unknown[74.201.28.92]
Oct  7 00:36:47 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:36:50 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:36:52 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:36:55 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:36:58 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:00 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:03 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:05 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:07 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:13 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:19 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:26 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:33 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:40 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:46 ns1 dovecot: imap-login: Login: user=<hello@systemscart.com>, method=PLAIN, rip=172.17.0.16, lip=213.136.87.29, mpid=239102, TLS, session=<2lGOy7bN2q2sEQAQ>
Oct  7 00:37:46 ns1 dovecot: imap(hello@systemscart.com)<239102><2lGOy7bN2q2sEQAQ>: Logged out in=68 out=873 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Oct  7 00:37:46 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:37:53 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:38:00 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:38:06 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:38:12 ns1 postfix/smtpd[232288]: warning: unknown[74.201.28.92]: SASL LOGIN authentication failed: authentication failure
Oct  7 00:38:14 ns1 postfix/smtpd[232288]: too many errors after AUTH from unknown[74.201.28.92]
Oct  7 00:38:14 ns1 postfix/smtpd[232288]: disconnect from unknown[74.201.28.92] ehlo=1 auth=0/20 rset=20 commands=21/41
You’re running Postfix 3 and on my CentOS systems I’ve not moved off the main EPEL repositories so I’m still on 2.10. However, the configs are mostly the same.
A few queries -
NB - if you use geoip-based checking in Postgrey, or any other software which invokes the GeoLite GeoIP.dat database, MaxMind now require an API key and account for using geoipupdate, and to download the actual GeoLite2 databases. https://dev.maxmind.com/geoip/geolite2-free-geolocation-data?lang=en
very very very thanks, the problem is resolved after deleting check_policy_service inet:127.0.0.1:10023 from the smtpd_recipient_restrictions
That’s great news. However, that will be required if you want to use Postgrey for greylisting, so bear that in mind. :slight_smile: Keep a backup of your previous config just in case, I always do!
Did you copy the configs from a tutorial or are they from your original installation?
