Ubuntu Server:
20.04LTS:
Just installed Virtualmin again thinking my previous installation had flaws but my problems still remains. I am having problems with SSL websites.
I have set up a FQDN its configured to have a SSL connection and lets encrypt was able to request and install this without issue.
When I visit this https://www.mydomain.com:10000 I can access virtualmin from both LAN and WAN.
My issue comes when i try to access a website just using SSL so if i was to visit https://www.mydomain.com I get ERR_CONNECTION_REFUSED message.
Firewall is configured to allow port 443. Router is set to Forward port 443 to destination server. however when I check which ports are listening I see 443 is only listening on IPV6 and this should have been disabled by default as my Provider does not currently support IPV6 addresses.
systemd-r 851 systemd-resolve 13u IPv4 28807 0t0 TCP 127.0.0.53:53 (LISTEN)
sshd 1633 root 3u IPv4 31239 0t0 TCP *:22 (LISTEN)
sshd 1633 root 4u IPv6 31241 0t0 TCP *:22 (LISTEN)
named 33503 bind 36u IPv4 104372 0t0 TCP 127.0.0.1:953 (LISTEN)
named 33503 bind 42u IPv4 105028 0t0 TCP 127.0.0.1:53 (LISTEN)
named 33503 bind 43u IPv4 105028 0t0 TCP 127.0.0.1:53 (LISTEN)
named 33503 bind 44u IPv4 105028 0t0 TCP 127.0.0.1:53 (LISTEN)
named 33503 bind 45u IPv4 105028 0t0 TCP 127.0.0.1:53 (LISTEN)
named 33503 bind 46u IPv4 105028 0t0 TCP 127.0.0.1:53 (LISTEN)
named 33503 bind 52u IPv4 106736 0t0 TCP 192.168.1.201:53 (LISTEN)
named 33503 bind 53u IPv4 106736 0t0 TCP 192.168.1.201:53 (LISTEN)
named 33503 bind 54u IPv4 106736 0t0 TCP 192.168.1.201:53 (LISTEN)
named 33503 bind 55u IPv4 106736 0t0 TCP 192.168.1.201:53 (LISTEN)
named 33503 bind 56u IPv4 106736 0t0 TCP 192.168.1.201:53 (LISTEN)
named 33503 bind 62u IPv6 105776 0t0 TCP [::1]:53 (LISTEN)
named 33503 bind 63u IPv6 105776 0t0 TCP [::1]:53 (LISTEN)
named 33503 bind 64u IPv6 105776 0t0 TCP [::1]:53 (LISTEN)
named 33503 bind 65u IPv6 105776 0t0 TCP [::1]:53 (LISTEN)
named 33503 bind 66u IPv6 105776 0t0 TCP [::1]:53 (LISTEN)
named 33503 bind 71u IPv6 105029 0t0 TCP [fe80::c23f:d5ff:fee2:c11a]:53 (LISTEN)
named 33503 bind 72u IPv6 105029 0t0 TCP [fe80::c23f:d5ff:fee2:c11a]:53 (LISTEN)
named 33503 bind 73u IPv6 105029 0t0 TCP [fe80::c23f:d5ff:fee2:c11a]:53 (LISTEN)
named 33503 bind 74u IPv6 105029 0t0 TCP [fe80::c23f:d5ff:fee2:c11a]:53 (LISTEN)
named 33503 bind 75u IPv6 105029 0t0 TCP [fe80::c23f:d5ff:fee2:c11a]:53 (LISTEN)
named 33503 bind 76u IPv6 104373 0t0 TCP [::1]:953 (LISTEN)
postgrey 50786 postgrey 5u IPv4 129506 0t0 TCP 127.0.0.1:10023 (LISTEN)
dovecot 63413 root 21u IPv4 147455 0t0 TCP *:110 (LISTEN)
dovecot 63413 root 22u IPv6 147456 0t0 TCP *:110 (LISTEN)
dovecot 63413 root 23u IPv4 150529 0t0 TCP *:995 (LISTEN)
dovecot 63413 root 24u IPv6 150530 0t0 TCP *:995 (LISTEN)
dovecot 63413 root 38u IPv4 150552 0t0 TCP *:143 (LISTEN)
dovecot 63413 root 39u IPv6 150553 0t0 TCP *:143 (LISTEN)
dovecot 63413 root 40u IPv4 150554 0t0 TCP *:993 (LISTEN)
dovecot 63413 root 41u IPv6 150555 0t0 TCP *:993 (LISTEN)
apache2 68729 root 4u IPv6 164179 0t0 TCP *:80 (LISTEN)
apache2 68729 root 6u IPv6 164183 0t0 TCP *:443 (LISTEN)
proftpd 70311 proftpd 0u IPv6 169676 0t0 TCP *:21 (LISTEN)
proftpd 70311 proftpd 1u IPv6 169677 0t0 TCP *:2222 (LISTEN)
spamd 76063 root 5u IPv6 183117 0t0 TCP [::1]:783 (LISTEN)
spamd 76063 root 6u IPv4 183119 0t0 TCP 127.0.0.1:783 (LISTEN)
spamd\x20 76095 root 5u IPv6 183117 0t0 TCP [::1]:783 (LISTEN)
spamd\x20 76095 root 6u IPv4 183119 0t0 TCP 127.0.0.1:783 (LISTEN)
spamd\x20 76096 root 5u IPv6 183117 0t0 TCP [::1]:783 (LISTEN)
spamd\x20 76096 root 6u IPv4 183119 0t0 TCP 127.0.0.1:783 (LISTEN)
mysqld 76902 mysql 22u IPv4 188032 0t0 TCP 127.0.0.1:33060 (LISTEN)
mysqld 76902 mysql 24u IPv4 186728 0t0 TCP 127.0.0.1:3306 (LISTEN)
/usr/shar 79383 root 3u IPv4 199050 0t0 TCP 127.0.0.1:11000 (LISTEN)
master 82445 root 13u IPv4 208214 0t0 TCP *:25 (LISTEN)
master 82445 root 14u IPv6 208215 0t0 TCP *:25 (LISTEN)
master 82445 root 110u IPv4 208312 0t0 TCP *:587 (LISTEN)
master 82445 root 111u IPv6 208313 0t0 TCP *:587 (LISTEN)
master 82445 root 114u IPv4 208318 0t0 TCP *:465 (LISTEN)
master 82445 root 115u IPv6 208319 0t0 TCP *:465 (LISTEN)
perl 82752 root 5u IPv4 207867 0t0 TCP *:10000 (LISTEN)
perl 82752 root 6u IPv6 207868 0t0 TCP *:10000 (LISTEN)
perl 82954 root 5u IPv4 208839 0t0 TCP *:20000 (LISTEN)
apache2 85724 www-data 4u IPv6 164179 0t0 TCP *:80 (LISTEN)
apache2 85724 www-data 6u IPv6 164183 0t0 TCP *:443 (LISTEN)
apache2 85725 www-data 4u IPv6 164179 0t0 TCP *:80 (LISTEN)
apache2 85725 www-data 6u IPv6 164183 0t0 TCP *:443 (LISTEN)
apache2 85726 www-data 4u IPv6 164179 0t0 TCP *:80 (LISTEN)
apache2 85726 www-data 6u IPv6 164183 0t0 TCP *:443 (LISTEN)
When i run a port check on 443 it does confirm port 443 is not currently open and having tried various things I just cannot get port 443 to listen for incoming connections
Can anyone provide some assistance.
