I am trying to migrate one web site to PHP7 but I want the other web sites to keep using whatever PHP they are using.
I first installed the php7 using this:
aptitude install php7.0 php7.0-mysql php7.0-cgi
aptitude install libapache2-mod-php7.0
/etc/init.d/apache2 restart
When I go here
Virtualmin -> Server Configuration -> PHP Versions:
I see:
This virtual server is using the mod_php or FPM execution mode for PHP, such does not allow per-directory version selection.
So I tried to fix this using:
Virtualmin -> Server Configuration -> Website Options:
PHP script execution mode [X] Apache CGI
But then I get ‘Internal Server Error’ when I load the web site.
In the log, I see this:
... AH01215: suexec policy violation: see suexec log for more details: ...
... End of script output before headers: php7.0.cgi
I did not change any permissions when adding PHP7.
The individual files seem to be 0644 and the folders are 0755.
PHP5.x is running fine with the current permissions.
Do I need to change the permissions before PHP7 can run?
Here is what I think are the relevant output of ‘Recheck Configuration’ :
Apache is installed.
The following PHP versions are available : 5.6.30 (/usr/bin/php5-cgi), 7.0.30 (/usr/bin/php-cgi7.0), 5.6 (mod_php)
PHP-FPM support was not detected : No FPM configuration directory found
Apache is configured to host SSL websites.
MySQL is installed and running.
The selected package management and update systems are installed OK.
Its for CentOS, but may be it can help you. I just use CentOS, never used other OS before, so I can’t help with that. But finding the log, it will make easier to solve your problem. I think…
The above allowed me to update webmin/virtualmin from virtualmin.
But then a new error message appeared: Your system’s primary IP address appears to have changed from xx.xx.xx.xx to yy.yy.yy.yy Virtual servers using the old address may be unreachable or serve the wrong web content.
and
The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home. CGI and PHP scripts run as domain owners will not be executed.
I tried this also just to be sure ‘aptitude install apache2’ and I got: apache2 is already installed at the requested version (2.4.25-3+deb9u5)
So I am not sure how to update ‘apache2’. I saw many post where people lose their web sites by reinstalling apache.
I am guessing this is a pretty standard problem since when you first install a linux server, you get asked if you want to install apache so most people would install it…
I also did this:
Virtualmin -> System Settings -> Server Templates -> Default Settings -> Apache Website
Automatically add appropriate SuExec directive [yes]
I retried ‘Virtualmin -> Server Configuration -> Website Options: PHP script execution mode [X] Apache CGI’ but this time I got: Failed to save website options : The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home. CGI and PHP scripts run as domain owners will not be executed.
Post the content of this files here. And try to add a new line with /home/ save the file and restart apache. So try to recheck the virtualmin configuration.
I tried adding the following in www-data: /home/
I restarted apache and did the recheck but got the same error: The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home. CGI and PHP scripts run as domain owners will not be executed.
I retried with just ‘/home’ without the ‘/’ at the end but got the same error.
The first two lines contain the suexec document root and the suexec userdir
suffix. Both features can be disabled separately by prepending a # character.
This config file is only used by the apache2-suexec-custom package.
If not fix, try to Disable the option Automatically add appropriate SuExec directive? under Virtualmin -> System Settings -> Server Template -> Default Settings -> Apache website
I tried the first part ‘apache2-suexec-custom’ but that did not change anything. I was still getting the error: The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin virtual server home directory is /home. CGI and PHP scripts run as domain owners will not be executed.
The option ‘Automatically add appropriate SuExec directive?’ set to no seems to get rid of that message though.
So I retried the original option at the top of the post:
But I still get ‘Internal Server Error’ when I load the web site using this option.
In the log, I still see this:
… AH01215: suexec policy violation: see suexec log for more details: …
… End of script output before headers: php7.0.cgi
I still don’t know where the suexec log is located… I retried ‘suexec -V’ but got this again: bash: suexec: command not found
I really dont know how to fix. Did you try to remove all apache package and reinstall then with virtualmin repo? You Virtualmin installation, how did you install? On fresh system? By installer?
No I did not reinstall apache. According to a post I read by Joe, just doing ‘apt-get install apache2’ would probably work. Is there a safe way to do this apache reinstall?
Is there an order for the repository in /etc/apt/sources.list since I put the virtualmin repository at first thinking it would take precedence. But perhaps I have to put it at the end? I mean that if there are more than one source for apache, how does aptitude know which one to take.
Also, I found the location of suexec log: /var/log/apache2/suexec.log
The error says: command not in docroot (/home/…
So the ‘/home’ I added in ‘/etc/apache2/www-data’ does not seem to work. Any idea why?
[EDIT]
Ok it was a typo on my part, I changed the folder to ‘/home’ in ‘/etc/apache2/suexec/www-data’ and now it works…
Also I finally found where is suexec on debian so ‘/usr/lib/apache2/suexec -V’ works and I can see the its configuration now.
Do you remember a link for ‘1)’ or ‘2)’? Maybe there is some explanation that could help me fix the problem.
I thought PHP was just an interpreter called when processing a web page. I am having difficulties understanding why a specific OS would be needed for this.
