Hi there, does anyone know how to install Percona with Virtualmin on Centos 6.4 or Debian 7? I found a useful topic but is on Ubuntu (http://www.virtualmin.com/node/25916).
I tried to install Percona on Debian 7 but failed as it needs the package libc6 >=2.14, while the default libc6 in Wheezy is libc6 2.13-38. The libc6 in Jessie and Sid is 2.17. However, I don’t want to use Jessie or Sid considering stability.
I also tried Centos 6.4 (actually Centos is my first choice), but also failed. It shows the following errors:
Error: mysql conflicts with Percona-Server-client-55-5.5.31-rel30.3.520.rhel6.x86_64
Error: mysql-server conflicts with Percona-Server-server-55-5.5.31-rel30.3.520.rhel6.x86_64
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Please let me know how to fix the problem if anyone knows (perhaps there are also many guys want to know it).
Hi andreychek, thank you for your reply! Yes I actually followed the Percona site’s instructions before but failed. It’s because of the libc6 problem (need to >=2.14). Now I hope to find a way to install Percona smoothly on Debian 7 or Centos 6.4 if anyone could give a hand which would be greatly appreciated.
and you are done - the only problem, you will not be able to start/stop/restart Percona server from Webmin (Percona uses /etc/init.d/“mysql” instead of “mysqld” script, so webmin doesn’t know about that)…
[root@server15 init.d]# ln -s mysql mysqld
[root@server15 init.d]# nano mysqld
[root@server15 init.d]# service mysqld restart
Shutting down MySQL (Percona Server)..... [ OK ]
Starting MySQL (Percona Server).. [ OK ]
