Htop snapshot:
1 [########################******* 48.6%] Tasks: 109, 73 thr; 2 running
2 [##############************ 41.7%] Load average: 4.34 4.19 3.33
Mem[||||||||||||||||||||||||||||||||||||||||||||*****2.71G/3.70G] Uptime: 13:20:08
Swp[ 0K/0K]
PID USER PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command
1319 root 20 0 2317M 32612 10568 S 0.7 0.8 1:20.63 python -s /usr/bin/fail2ban-server -xf start
871 nydus 20 0 1173M 39636 3664 S 0.7 1.0 2:17.66 python3.5 /opt/nydus/pyvenv/bin/nydus-ex-api
1534 nydus 20 0 1173M 39636 3664 S 0.7 1.0 1:05.74 python3.5 /opt/nydus/pyvenv/bin/nydus-ex-api
26338 apache 20 0 476M 16380 3892 S 0.7 0.4 0:00.06 httpd -DFOREGROUND
1308 root 20 0 2317M 32612 10568 S 0.7 0.8 0:13.40 python -s /usr/bin/fail2ban-server -xf start
1359 root 20 0 2317M 32612 10568 S 0.7 0.8 0:12.03 python -s /usr/bin/fail2ban-server -xf start
878 root 20 0 2317M 32612 10568 S 0.0 0.8 7:20.30 python -s /usr/bin/fail2ban-server -xf start
1580 mysql 20 0 1902M 278M 5840 S 0.0 7.3 6:08.25 mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/p
1586 root 20 0 412M 6936 5032 S 0.0 0.2 0:21.86 rsyslogd -n
1352 root 20 0 2317M 32612 10568 S 0.0 0.8 0:19.88 python -s /usr/bin/fail2ban-server -xf start
7775 **site** 20 0 454M 65744 44532 S 0.0 1.7 0:41.24 php-cgi
1413 root 20 0 2317M 32612 10568 S 0.0 0.8 2:08.65 python -s /usr/bin/fail2ban-server -xf start
1 root 21 1 52480 4144 2100 S 0.0 0.1 1:55.10 systemd --switched-root --system --deserialize 22
496 dbus 20 0 58256 2236 1536 S 0.0 0.1 1:22.59 dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activat
2198 **site** 20 0 454M 64320 43576 S 0.0 1.7 0:33.53 php-cgi
350 root 20 0 39480 5580 5204 S 0.0 0.1 0:55.73 systemd-journald
504 root 20 0 26488 1696 1332 S 0.0 0.0 0:41.56 systemd-logind
503 polkitd 20 0 598M 10140 2248 S 0.0 0.3 0:24.23 polkitd --no-debug
1602 root 20 0 412M 6936 5032 S 0.0 0.2 0:16.68 rsyslogd -n
534 root 22 2 354M 30424 3792 S 0.0 0.8 0:13.14 python2 -Es /usr/sbin/firewalld --nofork --nopid
524 polkitd 20 0 598M 10140 2248 S 0.0 0.3 0:13.18 polkitd --no-debug
1384 root 20 0 2317M 32612 10568 S 0.0 0.8 0:19.13 python -s /usr/bin/fail2ban-server -xf start
20131 apache 20 0 477M 18412 4688 S 0.0 0.5 0:00.28 httpd -DFOREGROUND
28509 apache 20 0 476M 16292 3720 S 0.0 0.4 0:00.02 httpd -DFOREGROUND
18663 mysql 20 0 1902M 278M 5840 S 0.0 7.3 0:00.45 mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/p
8491 mysql 20 0 1902M 278M 5840 S 0.0 7.3 0:23.95 mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/p
1401 root 20 0 2317M 32612 10568 S 0.0 0.8 0:22.21 python -s /usr/bin/fail2ban-server -xf start
13481 **site** 20 0 155M 2116 708 S 0.0 0.1 0:00.11 sshd: **site**@pts/0
1828 mysql 20 0 1902M 278M 5840 S 0.0 7.3 0:43.94 mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/p
1302 root 20 0 2317M 32612 10568 S 0.0 0.8 0:26.76 python -s /usr/bin/fail2ban-server -xf start
1338 root 20 0 2317M 32612 10568 S 0.0 0.8 0:18.68 python -s /usr/bin/fail2ban-server -xf start
25563 apache 20 0 477M 17352 3988 S 0.0 0.4 0:00.08 httpd -DFOREGROUND
417 root 16 -4 55532 1016 568 S 0.0 0.0 0:00.17 auditd
1368 root 20 0 2317M 32612 10568 S 0.0 0.8 0:19.58 python -s /usr/bin/fail2ban-server -xf start
416 root 16 -4 55532 1016 568 S 0.0 0.0 0:03.95 auditd
I changed usernames to site for security.
The VPS has 4GB RAM.
Real memory 1.89 GiB used / 1.64 GiB cached / 3.7 GiB total
From Virtualmin Running Processes
Fail2ban is using 2.2GB RAM.
CPU load averages: 4.41 (1 mins) , 4.22 (5 mins) , 3.30 (15 mins)
CPU type: Intel Core Processor (Haswell, no TSX, IBRS) (2394 MHz) , 2 cores
It’s a relatively new VPS with roughly 60 domains which I’m still trying to optimise for performance, optimising a server isn’t my area of expertise.
I’m new to Fail2ban and have recently set it to scan all access_log files for wp-login.php and xmlrpc.php access to reduce wasted resources.
The Fail2ban WordPress filter I built is scanning 40 access_log files which isn’t the best setup performance wise. Currently looking for a way to log wp-login.php and xmlrpc.php access to a custom log file via a plugin, but not got it working as I want it yet so keeping this setup until I get the custom log working.
Although I’m concerned at the memory usage of Fail2ban I’m more concerned at CPU load averages being relatively high, it tends to run at around 2 which I’m not happy about. Despite this the websites on the VPS are running fast, since adding the new WordPress Fail2ban rules it’s got faster, so blocking IPs which are trying to access wp-login.php and xmlrpc.php has made a positive difference to overall server performance.
I regularly test my sites with tools like Google Lighthouse and they load in under 2 seconds, so the VPS is doing what I want it to do. So I’m looking for possible problems to fix and the Fail2ban high RAM usage seemed like a problem, if it isn’t I’ll go looking for another problem
Thanks for your insights.
