How to remove SSL (HTTPS) Certificat in Virtualmin?
| SYSTEM INFORMATION||
| OS type and version | Ubuntu 20.04 LTS |
| Virtualmin version | 7.7-3 |
Hello all.
I want to remove SSL Certificat that I installed on Virtualmin. I prefer creating Let’s Encrypt SSL Certificat manually instead of using Virtualmin’s.
So, is there any way to remove it from Virtualmin Dashbord ???
Thanks for answering me.
Awaiting.
it is enough to disable SSL at the domain
and recreate the certificate
if files remain, they can be deleted after SSL is disabled.
if you use CHroot (The path and number of the created CHroot folder may be different.):
If without CHroot, files can be found in the “Home directory” of the domain.
