OS type and version
RHEL 9
Webmin version
2.101
Virtualmin version
7.8.2
When going to any domain on the server including the server host address /icons apache always lists a public icons folder.
I have a need to override or disallow that behavior for a single site under Vmin which has it’s own /icons folder.
Is there even a good reason to allow that behavior anyway?
jimr1
October 31, 2023, 5:19am
2
It does not you have something not setup correctly we will need more information to help you.
Standard setup, I try to avoid fiddling unless it’s withiin Virtualmin.
It’s a default behavior of Apache to alias /icons to /usr/share/httpd/icons
I can manually delete or comment out that alias - which applies to the entire server, but I was wondering if Vmin can do a fix on a per domain basis?
jimr1
October 31, 2023, 5:34am
4
wow never had that at all must be RHEL thing id don’t have the directory /usr/share/httpd/icons on my debian systems … oh well you learn something new everyday try this though it may help https://cloudblue.freshdesk.com/support/solutions/articles/44001883958-disabling-apache-http-server-indexing-of-icons-directory
If using apache, try going to any of your domains/icons and see what happens - I am curious too.
jimr1
October 31, 2023, 5:55am
6
I see
I wonder why rhel do that ?
Apparently it’s to do with FancyIndexed directory listings.
Also in Debian from what I just read.
jimr1
October 31, 2023, 6:08am
9
Oh well each to their own, I prefer debian’s approach, at least you know where you are, with no surprises on the way
jimr1
October 31, 2023, 6:28am
11
Well just installed apache2 on a fresh install of debian 12 and there is no /usr/share/httpd/icons directory in fact there is no /usr/share/httpd directory. I used localhost/icons and it still can not find the icons resource, I’m now curious can you point me to the article that states that debian also does this … maybe I am doing something wrong here ?
jimr1
October 31, 2023, 7:08am
13
Randomz:
It might be out of date.
everything is up to date, I even installed UB 22.04 and the same thing happens
now trying icons
I have a domain setup there as well and the same thing happens using a domain name rather than IP address.
I then made the icons directory in the document root & I now get
Try forward slash after icons …/icons/
Randomz
October 31, 2023, 8:35am
16
I meant that the article might be out of date for your Debian.
Anyway, I commented out the alias stuff which fixed my problem.
I am however interested if anyone can show that this can be done within Vmin.
I did some googling and found no solution.
jimr1
October 31, 2023, 9:21am
18
made no difference at all but I’m happy with that I don’t want some ‘shared’ directory shown
