pls help htacess not working
Options +FollowSymLinks
RewriteEngine on
RewriteRule ^showthread-([0-9])-([0-9])-(.+?).htm$ index.php?forumID=$1&ID=$2 [NC,L]
RewriteRule ^showthread-([0-9])-([0-9])–([0-9]*).htm$ index.php?forumID=$1&ID=$2&start=$3 [NC,L]
RewriteRule ^forumdisplay-(.+?)-([0-9]*).htm$ index.php?forumID=$2 [NC,L]
RewriteRule ^forumdisplay-([0-9])–([0-9]).htm$ index.php?forumID=$1&start=$2 [NC,L]
RewriteRule ^showprofile-([0-9]*)-(.+?).htm$ profile.php?userID=$1 [NC,L]
RewriteRule ^member/(.+?).htm$ profile_redirect.php?username=$1 [NC,L]
Hey there
Virtualmin automatically protects you from the +FollowSymLinks option which causes vulnerabilities. If you check your apache logs there will most likely be an entry explaining this.
To fix it, change +FollowSymLinks to +SymLinksIfOwnerMatch and restart apache.
If you are having other issues, then please post back with more details of what is “not working”.
Hope that helps
http://adda4m.com/forumdisplay-WWE-Section-65.htm
Options +SymLinksIfOwnerMatch
RewriteEngine on
done still geting
Not Found
The requested URL /forumdisplay-WWE-Section-65.htm was not found on this server.
please some one help
