| SYSTEM INFORMATION | |
| OS type and version | CentOS 7 |
| Webmin version | 2.105 |
Hi All,
How to install SSL on specific port using webmin?
Hi All,
not enough information, what are you trying to do ?
attach the ssl certificate to and instance of your web server running on a port other than 443 or something else ?
if the former it would be good to know what web server you are using
Sir,
I have installed First Tomcat instance on 8080 and SSL installed.
I want to install another 2 Tomcat instance on Port 8081 & Port 8082. Here I want to install SSL through webmin.
this will help I guess ssl - Multiple HTTPS Connectors in Tomcat using different certificates - Stack Overflow, this shows different certificates is this want you want to do ? or use the same certificate ?
Thanks for quick help. I will try.
I want to install different certificate for different port.
Webmin does not manage Tomcat.
Okay Sir, Thanks.
By the way I am following https://www.acugis.com/tomcat-webmin-modules/ article to install multiple tomcat instance.
Ah, I don’t know anything about that module, it’s not one we maintain.
I would generally recommend proxying to any application server rather than having the app server act as the world-facing web server.
Okay Sir, Thanks.
