I have a problem with mod_fcgid: read data timeout in 31 seconds.
I went to server configuration and changed php script time to 100, only to find out that I have to change fcgi time out. I was looking around and couldnt find it.
I found the following link where I think I found a solution to my problem.
Since you’re using mod_fcgi, each virtual server has its own PHP config file. You can edit it by selecting the server and then at “Services -> PHP5 configuration -> Resource limits”. Make sure the screen shows a config file name like /home/DOMAIN/etc/php5/php.ini. An Apache restart might be required after making changes.
I thought that I have to find fcgid.conf configuration.
I have increased PHP time out in server configuration
website options
maximum php script run time
