I’m stuck on fill out Initial login for script for Joomla script installation in Virtualmin
what are you stuck on? Its a standard form for the scripts.
How to fill out this form?
username & password perhaps
just add username and password, its not rocket science ![]()
I did it, but wasn’t worked
you did add the username & password for the domain owner or did you just create new ones ?
Domain owner and owner password
But it’s not working
raise a support ticket, that’s not normal.
OP is a GPL user, support tickets are for Pro customers. Discussing the problem here is the right thing.
Though Joomla is a Pro-only Install Script…so, not sure what we’re seeing here. Maybe OP is a Pro subscriber on a different account. I dunno.
