how can I disable Bandwidth Monitoring in Webmin module? After enable it for test on eth0 there isn’t any check for turn off this.
For system Firewall I’m using shorewall.
Well, I don’t have shorewall on my test system here – but when I go into Webmin -> Networking -> Bandwidth monitoring, and enable it, it presents a new button labeled “Turn Off Monitoring”.
Are you saying that when you go back into the Bandwidth Monitoring screen, there’s no Turn Off Monitoring button?
If not, what options are displaying there?
Hi Eric,
I haven’t the “Turn Off” button. See the screenshot.
Okay, first, that has to be the smallest screenshot ever
But, I can kind of read it… it looks as if Virtualmin thinks bandwidth monitoring is not currently enabled.
Are you certain that it is?
Can you attach two more files:
One containing the output of the command: iptables -L -n
The other containing the output of running “crontab -l” as root.
Thanks!
Hi Eric,
thanks for the reply and sorry for the small screenshot . I’m not using Virtualmin
14 0 * * * /etc/webmin/cron/tempdelete.pl
0 * * * * /etc/webmin/bandwidth/rotate.pl
Chain INPUT (policy DROP)
target prot opt source destination
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 7 prefix BANDWIDTH_IN:' LOG 0 -- 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 7 prefix
BANDWIDTH_IN:’
ACCEPT 0 – 0.0.0.0/0 0.0.0.0/0
eth0_in 0 – 0.0.0.0/0 0.0.0.0/0
Reject 0 – 0.0.0.0/0 0.0.0.0/0
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:INPUT:REJECT:’
reject 0 – 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy DROP)
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 7 prefix BANDWIDTH_OUT:' LOG 0 -- 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 7 prefix
BANDWIDTH_IN:’
eth0_fwd 0 – 0.0.0.0/0 0.0.0.0/0
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:FORWARD:REJECT:’
Chain OUTPUT (policy DROP)
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 7 prefix BANDWIDTH_OUT:' ACCEPT 0 -- 0.0.0.0/0 0.0.0.0/0 fw2net 0 -- 0.0.0.0/0 0.0.0.0/0 policy match dir out pol none Reject 0 -- 0.0.0.0/0 0.0.0.0/0 LOG 0 -- 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix
Shorewall:OUTPUT:REJECT:’
Chain Drop (2 references)
reject tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:113
dropBcast 0 – 0.0.0.0/0 0.0.0.0/0
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmp type 3 code 4
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmp type 11
dropInvalid 0 – 0.0.0.0/0 0.0.0.0/0
DROP udp – 0.0.0.0/0 0.0.0.0/0 multiport dports 135,445
DROP udp – 0.0.0.0/0 0.0.0.0/0 udp dpts:137:139
DROP udp – 0.0.0.0/0 0.0.0.0/0 udp spt:137 dpts:1024:65535
DROP tcp – 0.0.0.0/0 0.0.0.0/0 multiport dports 135,139,445
DROP udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:1900
dropNotSyn tcp – 0.0.0.0/0 0.0.0.0/0
DROP udp – 0.0.0.0/0 0.0.0.0/0 udp spt:53
Chain Reject (4 references)
reject udp – 0.0.0.0/0 0.0.0.0/0 multiport dports 135,445
reject udp – 0.0.0.0/0 0.0.0.0/0 udp dpts:137:139
reject udp – 0.0.0.0/0 0.0.0.0/0 udp spt:137 dpts:1024:65535
reject tcp – 0.0.0.0/0 0.0.0.0/0 multiport dports 135,139,445
Chain all2all (0 references)
ACCEPT 0 – 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:all2all:REJECT:’
Chain dropBcast (2 references)
DROP 0 – 0.0.0.0/0 0.0.0.0/0 PKTTYPE = broadcast
DROP 0 – 0.0.0.0/0 0.0.0.0/0 PKTTYPE = multicast
Chain dropInvalid (2 references)
DROP 0 – 0.0.0.0/0 0.0.0.0/0 state INVALID
Chain dropNotSyn (2 references)
DROP tcp – 0.0.0.0/0 0.0.0.0/0 tcp flags:!0x17/0x02
Chain dynamic (2 references)
Chain eth0_fwd (1 references)
dynamic 0 – 0.0.0.0/0 0.0.0.0/0 state INVALID,NEW
smurfs 0 – 0.0.0.0/0 0.0.0.0/0 state INVALID,NEW policy match dir in pol none
norfc1918 0 – 0.0.0.0/0 0.0.0.0/0 state NEW policy match dir in pol none
tcpflags tcp – 0.0.0.0/0 0.0.0.0/0 policy match dir in pol none
Chain eth0_in (1 references)
net2fw 0 – 0.0.0.0/0 0.0.0.0/0 policy match dir in pol none
Chain fw2net (1 references)
Chain logdrop (0 references)
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:logdrop:DROP:’
Chain logflags (5 references)
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:logflags:DROP:’
Chain logreject (0 references)
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:logreject:REJECT:’
Chain net2all (0 references)
Drop 0 – 0.0.0.0/0 0.0.0.0/0
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:net2all:DROP:’
Chain net2fw (1 references)
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmp type 8
ACCEPT tcp – 79.48.96.156 0.0.0.0/0 tcp dpt:22
ACCEPT tcp – 83.211.186.6 0.0.0.0/0 tcp dpt:22
ACCEPT tcp – 88.149.155.248 0.0.0.0/0 tcp dpt:22
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:80
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:21
ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:53
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
ACCEPT tcp – 79.48.96.156 0.0.0.0/0 tcp dpt:3306
ACCEPT tcp – 83.211.186.6 0.0.0.0/0 tcp dpt:3306
ACCEPT tcp – 88.149.155.248 0.0.0.0/0 tcp dpt:3306
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:10000
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:net2fw:DROP:’
Chain norfc1918 (2 references)
rfc1918 0 – 172.16.0.0/12 0.0.0.0/0
rfc1918 0 – 0.0.0.0/0 0.0.0.0/0 ctorigdst 172.16.0.0/12
rfc1918 0 – 192.168.0.0/16 0.0.0.0/0
rfc1918 0 – 0.0.0.0/0 0.0.0.0/0 ctorigdst 192.168.0.0/16
rfc1918 0 – 10.0.0.0/8 0.0.0.0/0
rfc1918 0 – 0.0.0.0/0 0.0.0.0/0 ctorigdst 10.0.0.0/8
Chain reject (11 references)
DROP 0 – 255.255.255.255 0.0.0.0/0
DROP 0 – 224.0.0.0/4 0.0.0.0/0
REJECT tcp – 0.0.0.0/0 0.0.0.0/0 reject-with tcp-reset
REJECT udp – 0.0.0.0/0 0.0.0.0/0 reject-with icmp-port-unreachable
REJECT icmp – 0.0.0.0/0 0.0.0.0/0 reject-with icmp-host-unreachable
REJECT 0 – 0.0.0.0/0 0.0.0.0/0 reject-with icmp-host-prohibited
Chain rfc1918 (6 references)
LOG 0 – 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:rfc1918:DROP:’
Chain shorewall (0 references)
Chain smurfs (2 references)
LOG 0 – 195.225.169.255 0.0.0.0/0 LOG flags 0 level 6 prefix Shorewall:smurfs:DROP:' DROP 0 -- 195.225.169.255 0.0.0.0/0 LOG 0 -- 255.255.255.255 0.0.0.0/0 LOG flags 0 level 6 prefix
Shorewall:smurfs:DROP:’
LOG 0 – 224.0.0.0/4 0.0.0.0/0 LOG flags 0 level 6 prefix `Shorewall:smurfs:DROP:’
Chain tcpflags (2 references)
logflags tcp – 0.0.0.0/0 0.0.0.0/0 tcp flags:0x3F/0x29
logflags tcp – 0.0.0.0/0 0.0.0.0/0 tcp flags:0x3F/0x00
logflags tcp – 0.0.0.0/0 0.0.0.0/0 tcp flags:0x06/0x06
logflags tcp – 0.0.0.0/0 0.0.0.0/0 tcp flags:0x03/0x03
logflags tcp – 0.0.0.0/0 0.0.0.0/0 tcp spt:0 flags:0x17/0x02
Now, I have find in the /etc/shorewall/ the “start” file added by Webmin:
~# cat /etc/shorewall/start
run_iptables -I INPUT -i eth0 -j LOG --log-prefix BANDWIDTH_IN: --log-level debug
run_iptables -I FORWARD -i eth0 -j LOG --log-prefix BANDWIDTH_IN: --log-level debug
run_iptables -I FORWARD -o eth0 -j LOG --log-prefix BANDWIDTH_OUT: --log-level debug
run_iptables -I OUTPUT -o eth0 -j LOG --log-prefix BANDWIDTH_OUT: --log-level debug
So, for disabiling Bandwidth monitor is sufficient delete the “start” file and remove the cron entry ?
Why my installation not have the “Turn Off” button?
Thanks.
Okay, well, it certainly appears as though the monitoring is active.
While we could probably manually disable it by altering the Shorewall start file and cron entries that you mentioned – you might also consider filing a bug report (using the Support button above).
At that point, Jamie can a look and fix the issue, as well as make sure those are really the only steps needed to disable it.
