Hi guys,
using the Virtualmin interface, how can we create a swapfile and size it to say 2GB?
i can create the file in Virtualmin File Manager, however, i dont know how we size it?
Also, are the any other things that have to be done to a swap file?
Hi guys,
I don’t know how you’d do it in the GUI.
Here’s the basic steps (note below I’m using /swapfile as the swap name…which is the same name the Virtualmin install.sh uses if you created swap at install time; you probably want to delete it and create bigger one instead of adding another…see below for how):
Make an empty file of e.g. 2GB (must be root or use sudo):
# dd if=/dev/zero of=/swapfile bs=1024 count=2097152
Set it to only be readable by root (because memory can contain anything, including sensitive data):
# chmod 600 /swapfile
Format it for swap usage:
# mkswap /swapfile
Enable it in /etc/fstab (skip this if you already had swap on /swapfile):
# echo '/swapfile none swap sw 0 0' >> /etc/fstab
Turn it on:
# swapon -a
If you already have swap on /swapfile, do the following first:
# swapoff -a
# rm /swapfile
And, then do the above steps.
ok. i missed that part in the other thread about this. i have actually just turned off the swapfile and increased its size, then chmod 600 and then turned it back on again.
