How to configure G Suite on a domain
Webmin version 2.111
Usermin version 2.010
Virtualmin version 7.20.2 Pro
Theme version 21.10
Package updates 9 package updates are available
Hello friends please how to configure G Suite on a domain on my vittualmin pro thank you
Its no longer G Suite it Google Workspace.
Only thing you need to do is edit DNS settings. Hosting of mail is not with Virtualmin.
merci pour l’aide mais j’ai pas compris et c’est ce que j ai trouver je ne sais pas comment remplir ca merci pour l aide
I think SMTP.GOOGLE.COM, normally you should be told the settings when it is setup in the control panel of google workspace or they email the client.
mr please even if I enter the link I can’t find the name that is shown on the photo please if you can help me tell me what I should write in each box if not I can’t find anything on the link because I’m not a pro thank you very much at my friend
Remove or edit current MX if there is one and add this
should show
The docs say
so check with client.
I have one client using it and they use the second option.
I also noticed they added a cname for mail.example.com to ghs.google.com so the client can collect mail.
but docs have a different address.
The fact you used the name G Suite sounds like its a old setup.
please if you can help or explan to me my problem
Maybe disable mail seeing your using Google Workspace, says it in the error.
