Hello all !
Does, any of you, know how to easily backup 100% of a website within Webmin ?
For 100%, I mean SQL databases and all the files (php, conf, images, media,…) included in a standard website.
Thank you for any help
Greeting,
Hello all !
Greeting,
Just to verify – you’re using Webmin, and not Virtualmin?
Virtualmin provides a quick and easy way for this, as it’s designed for web hosting. You could just go into Backup and Restore, and generate a backup of any domains hosted on your server.
If you’re just using Webmin, you’d need to generate a backup of your databases, and then generate a filesystem backup that includes both your websites, as well as your Apache configs. In the MySQL Database module is a “Backup Databases” option. And in the Filesystem Backup module, you can backup your files and configs.
