I hope someone can help with this. One of our servers is a bit unstable and I just want to double check how much RAM dom0 should be using, running CloudMin GPL?
Are you seeing an issue with how much RAM is in use?
How much RAM is in use is determined by the services running and how they’re being used… but Cloudmin itself is actually rather small, and is just a Webmin module. The needs of Cloudmin are more related to the disk space needed to store disk images, if you’re using it to provision new VPS’s.
You can tell how much RAM Cloudmin (and thus, Webmin/Virtualmin) are using by looking at the miniserv.pl processes running.
Does that answer your question?
When I login to Cloudmin, I see this:
Real memory 5.82 GB total, 4.35 GB used
And it’s rather unstable, needs to be hard rebooted manually from time to time. So I’m trying to figure out what’s causing the problem. Another similar specced server which runs HyperVM doesn’t give any problems, with more VM’s running on top of it than this one.
Well, the key would be to review what all is taking up RAM.
The first thing I’d do is to get a first hand look at the RAM in use on your server, by logging in as root via SSH, and typing: free -m
What output do you get from that command?
Then, I’d suggest reviewing what processes you see running in a “ps auxw”, and make sure they should all be running, and that none are taking up an abnormally large amount of RAM.
Feel free to post your process list here if you’d like a few extra eyes taking a look to see if it’s normal
It seems that “miniserv.pl” uses up the most resources, but also that it could be a memory leak, or runaway process.
Look at this:
top - 00:20:40 up 8 days, 14:22, 2 users, load average: 0.12, 0.15, 0.10
Tasks: 1150 total, 3 running, 1147 sleeping, 0 stopped, 0 zombie
Cpu(s): 1.0%us, 1.0%sy, 0.0%ni, 98.0%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 5837824k total, 5751948k used, 85876k free, 119716k buffers
Swap: 4194296k total, 2630592k used, 1563704k free, 384568k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
5594 root 15 0 95700 28m 1740 S 0.0 0.5 0:02.18 miniserv.pl
13228 root 15 0 127m 25m 1572 S 0.0 0.4 0:00.47 lfd
689 root 15 0 99292 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
723 root 15 0 99292 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
31369 root 15 0 99292 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
31705 root 15 0 99292 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
16118 root 15 0 99296 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
15795 root 15 0 99308 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
15465 root 15 0 99300 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
15144 root 15 0 99296 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
14812 root 15 0 99288 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
14491 root 15 0 99280 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
14167 root 15 0 99276 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
13835 root 15 0 99268 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
12800 root 15 0 99160 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
12144 root 15 0 99160 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
12468 root 15 0 99160 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
11815 root 15 0 99160 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
10848 root 15 0 99172 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
10509 root 15 0 99164 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
10182 root 15 0 99164 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
9853 root 15 0 99168 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
9521 root 15 0 99176 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
9198 root 15 0 99168 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
8824 root 15 0 99164 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
8488 root 15 0 99152 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
8164 root 15 0 99144 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
7515 root 15 0 99132 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
7839 root 15 0 99140 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
7187 root 15 0 99032 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
6865 root 15 0 99032 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
6546 root 15 0 99032 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
6223 root 15 0 99032 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
5894 root 15 0 99032 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
5569 root 15 0 99032 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
4521 root 15 0 99040 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
4186 root 15 0 99052 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
3848 root 15 0 99044 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
3516 root 15 0 99048 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
3187 root 15 0 99044 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
2844 root 15 0 99036 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
2501 root 15 0 99028 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
2164 root 15 0 99024 21m 272 S 0.0 0.4 0:00.00 miniserv.pl
What do you suggest I do with this?
What output do you get if you run:
ps auxw | grep miniserv
That should show a little extra info about the processes.
I did some goole on this, just after posting my response and the only posts related to miniserv.pl was related to large spam filter on virtualmin.
But, since I wanted to move this server to a CloudMin commercial one, I thought I’d just uninstall Webmin completely and reinstall it from CloudMin. Since then it hasn’t giving problems yet.
