I am still getting a lot of spam. I need to add or tweak some settings asap. I think most of the spam would fail the dcc filter, as most of it fits a generic pattern. I noticed that DCC is not enabled by default. What are the steps that I need to take to enable the DCC filter?
Have you enabled greylisting? You can do that in Email Messages -> Email Greylisting.
You can use things like DCC and Pyzor, but you’ll need to manually install the packages to get that working.
There’s a lot of info about that in the SpamAssassin wiki – for example, DCC configuration instructions are here:
