I want to change the Usermin :20000 login page to say something like:
"Complete email address required for login to "
I downloaded the Authentic Theme as a .gz in my browser. I found two likely files, “theme.info” (which contains “Authentic Theme”… I hoping to name the something else so as not to break the original if a fix for “Automatically try appending domain name to usernames?” turns up) and “en” which contains the text but the edited versions appear to save in 7zip on Windows but then do not.
The .gz file itself contains only one file, and .ubt file (which acts like a folder in 7zip, but can be directly edited with notepad as well). The text I want to change is there as well (at least the login text is, I would be unlikely to know how to rename the theme) but I can’t save that either (it gives me an error about the file being opened by something else).
I can extract the .ubt file and edit it but 7zip doesn’t zip back to .gz. It does to .tar though, but the Install Theme won’t accept it (it says “:File does not appear to contain any modules”. I can upload the edited .ubt file directly but it says “: Not a valid module file : tar: This does not look like a tar archive tar: Skipping to next header tar: Exiting with failure status due to previous errors”.
Is there a guide somewhere to making or editing themes? (It’s such a small change I was sure I’d be able to just make a slightly altered version of the original and switch to it for now.). Would I have better luck using gzip on the Ubuntu itself?
Thanks.
| SYSTEM INFORMATION | |
| OS type and version | Ubuntu 24.04.1 |
| Virtualmin version | 7.20.2 |
