Do I need to manually create a subdomain by editing http.conf and dns files to made subdomains… ?
But I would think that I can give a way to have a user or even root admin to make subdomains by the control panel.
So I know I can add a CNAME for blog.somesite.com from the "Services --> DNS Domains " …
But is there a easy way to add the Apache part ? – > Configure Website --> Aliases and Redirects …
But with out some information about how that page works I hate to just play to find out…
You don’t need to manually edit anything; just choose to create a new Virtual Server, or Sub-Server, and enter the name of the sub-domain you’d like to use.
Virtualmin will handle creating the Apache and BIND records for you.
This creates a brand new (sub) server going to /home//domains//public_hmtl what he (and i) need is sub-server.topserver.tld beeing served from /home//public_html/>sub-server>
is that possible?
Previous version of Virtualmin has supported Sub Domain, but they drop it and support Sub-Server instead. I have explain in details and hope Virtualmin bring back Sub Domain feature again, see: http://www.virtualmin.com/node/18008#comment-100842
