how do i add webmail / SquirrelMail for
Virtualmin Pro main server and all virtualman domain server’s
for web mail access.
So, would you like Squirrelmail to be the primary webmail client for your Virtual Servers?
For example, right now, if you go to webmail.YOUR_DOMAIN.com, you’ll go to usermin. Would you like that to be Squirrelmail?
To do that, my recommendation would be to pick a "primary" domain, and add Squirrelmail to it, and perhaps even setup SSL for that site.
And then, go into System Settings -> Server Templates -> Apache Website, and update "URL for webmail redirect".
That will handle it for new domains – for existing domains, you can use the command line program "modify-web.pl" to update the webmail link for all the existing Virtual Servers, by simply disabling it, then re-enabling it once you update the server templates:
http://www.virtualmin.com/documentation/id,virtualmin_api_modify_web/
Having problems with e-mail
Can’t send or receive mail see error below.
webmail,pop3 or imap not working.
nslookup works
ping works
digg works
telnet works
Error:from e-mail client
This is the mail delivery agent at messagelabs.com.
I was not able to deliver your message to the following addresses.
<username@domain.com>:
xxx.xxx.xxx.xxxdoes not like recipient.
Remote host said: 550 5.1.1 <username@domain.com>: Recipient address rejected: User unknown in virtual alias table
Mail client errors are not useful for debugging mail problems. We need to see the relevant part of the mail log. See the troubleshooting common problems guide email section for where to find the logs and how to…troubleshoot common problems.
http://www.virtualmin.com/documentation/id,troubleshooting_common_problems/#email
Also, it’s best to start a new topic when talking about a different subject, rather than picking up on an existing thread.
