How do I add Nginx to Features and Plugins
Webmin version 2.001
Virtualmin version 7.2-1
Related packages nginx
I believe that when I installed Virtualmin, I chose the default LAMP instead of LEMP. I removed Apache from the system and installed Nginx. I have a few websites that have Nginx-enabled websites. However I don’t see Nginx in the list of available “Features and Plugins” in Virtualmin. Can I just install the virtualmin-lemp-stack-minimal package to get Nginx to be recognized with Webmin/Virtualmin? Is this going to mess up the sites I already have configured with Nginx by overwriting their configurations or something?
These are the changes it will make:
# apt install virtualmin-lemp-stack-minimal
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
  awstats bind9 bind9-utils certbot clamav clamav-base clamav-freshclam
  etckeeper fcgiwrap firewalld geoip-database gir1.2-nm-1.0 ipset
  jailkit libclamav9 libdbd-mysql-perl libdbi-perl libgeoip1
  libhiredis0.14 libipset13 libmemcachedutil2 libnet-xwhois-perl
  libnginx-mod-http-auth-pam libnginx-mod-http-dav-ext
  libnginx-mod-http-echo libnginx-mod-http-subs-filter
  libnginx-mod-http-upstream-fair libnm0 libtfm1 mysql-client nginx-full
  ntpdate php-pear proftpd-basic proftpd-core proftpd-doc
  proftpd-mod-crypto proftpd-mod-wrap python3-acme python3-cap-ng
  python3-certbot python3-configargparse python3-distutils
  python3-firewall python3-icu python3-josepy python3-jsonschema
  python3-lib2to3 python3-nftables python3-parsedatetime
  python3-pyrsistent python3-rfc3339 python3-setuptools python3-tz
  python3-zope.component python3-zope.event python3-zope.hookable quota
  spamc unrar webalizer webmin-virtualmin-nginx
  webmin-virtualmin-nginx-ssl zip
Suggested packages:
  libnet-dns-perl libnet-ip-perl libgeo-ipfree-perl bind-doc resolvconf
  python-certbot-doc python3-certbot-apache python3-certbot-nginx
  libclamunrar clamav-docs libclamunrar9 libmldbm-perl
  libnet-daemon-perl libsql-statement-perl geoip-bin nginx-doc
  openbsd-inetd | inet-superserver proftpd-mod-ldap proftpd-mod-mysql
  proftpd-mod-odbc proftpd-mod-pgsql proftpd-mod-sqlite
  proftpd-mod-geoip proftpd-mod-snmp python-acme-doc
  python-jsonschema-doc python-setuptools-doc libnet-ldap-perl rpcbind
  spamassassin postgresql postgresql-client libdbd-pg-perl libpg-perl
  clamav-daemon clamav-testfiles libconfig-inifiles-perl postgrey
  milter-greylist
The following NEW packages will be installed:
  spamc unrar virtualmin-lemp-stack-minimal webalizer
  webmin-virtualmin-nginx webmin-virtualmin-nginx-ssl zip
0 upgraded, 65 newly installed, 0 to remove and 0 not upgraded.
Need to get 15.8 MB of archives.
After this operation, 58.7 MB of additional disk space will be used.
In this case scenario we always recommend to re-install, as it will be much faster for any regular user then fixing a problem.
When installing Virtualmin make sure to choose the correct bundle. For LEMP stack (with Nginx set as default web server) run:
sh virtualmin-install.sh -b LEMP
Thanks for the response, but that seems like it would probably be really destructive. I don’t want it to overwrite all of the settings. Executing apt install webmin-virtualmin-nginx webmin-virtualmin-nginx-ssl seemed to have done the trick and it only installed those two packages.
Then you should also run:
virtualmin-config-system -i=Nginx
I’m not sure if executing that was necessary since it appeared to work without it, but thanks.
