Howdy.
Ive just set up my home server running virtualmin imported my old backup and all is well the check tell’s me everything is fine.
But when I go to
http://craftybluefox.com/
or even
http://81.108.2.122/
I get error 522 (From cloudflare which means https://support.cloudflare.com/hc/en-us/articles/200171906-Error-522 )
My router is all set to allow the vmware server
I’m out of ideas and hoping someone can help
Cheers
Eric
June 10, 2014, 6:24pm
2
What happens when trying to remotely connect to port 80 on your server? If your server is behind a NAT router, is port 80 being forwarded to your server?
Well when I go to http://192.168.146.130/ on my server (That ip is the Vmware server) it shows the apache “it works” screen Eric
Fixed it Eric was a problem with VMware’s network. Sorry about that and thanks for the help.
Eric got a new problem now. I did the restore with zero errors but if you look here http://craftybluefox.com/
I just get the “it works” page showing and not the site.
Abit more of info here when I go to preview the site I get this “Connections to IP addresses not on this system are not allowed : 81.108.2.122” ?
Eric
June 10, 2014, 8:29pm
7
Receiving the “It Works” page may be a sign of an IP address mismatch within your Apache config.
Take a peek at the section “The Wrong Site Shows Up” in the following documentation, and see if this helps to resolve your issue:
https://www.virtualmin.com/documentation/web/troubleshooting
Yes ive been reading that page but found nothing which was wrong. I’m of to reinstall the whole lot so back in abit
