Hide / bypass Dashboard, show other info to reduce CPU & RAM usage on login / switch
When logging in or switching between Webmin and Virtualmin, is it possible to configure the system to bypass the Dashboard and show other info like Virtual Server Summary instead?
The Dashboard is too resource intensive and draws upon RAM and CPU which may impact the performance of other processes on low configuration systems. I use a workaround of launching Virtualmin via the following link / shortcut to bypass the Dashboard
https://vps.domain.tld:10000/virtual-server/?xnavigation=1
This too consumes RAM and CPU but less than the Dashboard does. It would be nice to have a configuration option in Virtualmin which would produce the same result from the default URL.
Authentic theme configuration, ā€˜default pages’ dropdown. I also turn off real time monitoring on that same page.
Thanks @scotwnw, this does produce the result that I was after. :+1:
