Hi , well i am totally new to this and I need help. I am running virtualmin just bought ( oct-21-2009 ) so i guess it is the newest update if that matters.
My problem.I am trying to understand how to get a cron command to work. i have the command that works in my web browser but when i put it into virtualmin or i should say the webmin tab on virtualmin, to create a cron job… I get lost…
I am trying to get ffmpeg player to work with “jomsocal” for joomla 1.5 and jomsocal needs to have a cronjob run to convert the videos… so that is why i want to use a cron job
ffmpeg is installed in /usr/bin
it works from the web command i have…
so what i do it the following:
Create a new scheduled cron job ( I make sure it is the root user) i guess root will run everything.
Job is ACTIVE…
Command ( I do not know what to put here)
Input to command ( I do not know what to put here)
but here is the command that I use to put into my web browser url and it works…
http://mydomain.com/rob/?option=com_community&task=cron
can anyone tell me what the coron command would be that i need to use and where to put it PLEASE:)
sorry i am so new at this and i just do not understand.
thank you and thank you for your time…
