Help Vlan On Webmin
OS type and version REQUIRED
Webmin version REQUIRED
I need help with sharing vlans using webmin interface I can’t find any tutorials
Can you expand on this ? the question gives no OS/ webmin information also from the question I’m unsure on what you want to do
how can i split vlan on webmin interface i cant find vlan item , my purpose is to split vlan then create dhcp server with multiple vlan down to client
I’ve seen none response to that question for webmin, it was a no 14 years ago.
https://webadmin-list.narkive.com/DzoeWHb4/webmin-l-network-vlan-interface
I would say you would need to do it outside webmin’s control.
You cannot split Webmin services between VLANs.
VLAN is not really for Webmin, I don’t think it ever will be because it would require specialist code and with Webmin being and endpoint (server) I am not sure how it would control VLANs.
You can just do this on your network hardware.
Look into tagged and untagged.
I’m not sure that you need VLAN’s on the machine issuing DHCP as long as it is reachable by the VLAN’s. It’s been over a decade since I’ve had any experience with this though.
wiki.linuxfoundation.org/networking/vlan
