Hi, i’m trying to use virtuamin gpl http api and i need help with some features:
a) create a new virtual server adding a personal plan like this:
if i use this synthax from browser it says: Unknown plan name, but i’m sure that this plan exists
in my virtualmin, so i need help or i think i use a wrong synthax.
b) edit the domain name in a existing virtual server using the same synthax on point a)
c) disable an existing domain using the same synthax on point a)
d) delete an existing domain using the same synthax on point a)
p.s. i changed port for api calls so don’t care about 10000 missing
i need help, sure for a sincerly reply,
Nerdy
